problem on my greddy blue box developing of late.
ok, first off.....
NO!!!! i'm not getting rid of the blue box and doing the hack or hondata!!! no FUCING money for that **** so don't jump on that horse in this post.
ok, now the problem. been boosting my greddy kit with blue box for over a year and in the past few months I've noticed that I chew through a set of plugs about once a month or so.
I use premium gas, intercooled, 8psi, and ngk's (i've tried normal, step colder, 2 step colder) and after about a month under hard top end acceleration the car will start to skip some, I change the plugs and all is good for another month.
what can i do to stop this? I've got a full-on MSD ignition setup under hood so i know it's not spark strength. I've tried setting gap at .044 (stock), and .035 (what other run) and still happens.
any ideas? i'm getting sick of riding around town for a month and then RIGHT when the problem surfaces some kid wants to try me and i have to back off cause I'm skipping
yeah, i was probably thinking it was the blue box. just wondering if others were having the same problems I was.
only reason I said what I did about the hack and such was because I knew there'd be a million one line posts like:
"go with the hack"
and that's not what I was needing...
"go with the hack"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">yeah, i was probably thinking it was the blue box. just wondering if others were having the same problems I was.
"go with the hack"
and that's not what I was needing...</TD></TR></TABLE>
well i have the blue box too.
i have an afc and injectors sitting in my bedroom waiting for the winter to be over.
Ijustified buying it because it will save me money from my horribelgas mileage with the blue box ( i get 190 to the tank on a good week!)
"go with the hack"
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
One of the drawbacks to the blue box is that it fouls out plugs fairly quickly (usually every 5k) due to running so rich. But in your case, I don't know what's wrong. Are you sure it's not a timing issue? I mean, you are running stock timing at 8 psi. Retard it 1 degree at the distributor and get some BKR6E's or 7E's, gapped at...well for a stock ignition, .030-.032. I don't know what you'd need for gap on your setup. Try retarding timing and getting new plugs first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR »</TD></TR><TR><TD CLASS="quote">try gapping even lower. Try a gap like .028?</TD></TR></TABLE>
That's what I was going to suggest. Can't hurt to try
if you are running to rich maybe invest in an adjustable fuel pressure regulator and lower the fuel pressure. Also I would retard your timing at the distributor like 3-4 degrees since the blue box doesnt adjust the ignition for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">
won't going too small on the gap hurt it too??
actually, I was thinking of further band-aiding it up a little bit by leaning it out some. Thinking about either turning down the fuel pressure a little bit or turning up the boost to 10psi again as I had it there for a long time and had no fouling problems.
</TD></TR></TABLE>won't going too small on the gap hurt it too??
Can you take a picture of one of your plugs?
I dont think he is detonating...if he was detonating that consistantly his rings and other internals would long be gone by now.
How are your compression numbers?
He has msd ignition i believe...
on another note ... since its running rich why not turn up the boost 1psi or 2... to try and lean it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">Can you take a picture of one of your plugs?
compression is fine, no smoking at all. I know i'm running rich from the nice black ring that has developed around the outer opening of my tailpipe
I tried a while back to take pics of my plugs but my digital camera is horrible and wont take close-ups.
they actually look normal with a white porcelain area, the black soot on the bottom of the threaded part, and no wear on the electrodes, etc so I have no clue. I'm just going to turn up the boost a little bit and swap the plugs again.
hell, it's only $8 for a set....just a pain in the *** to do once a month is all.
Pfieff
Aug 17, 2003 06:00 PM
turbod16y7vtec
Dec 12, 2002 08:48 AM
