problem help please
Old May 25, 2007 | 06:46 PM
lakai_19's Avatar
Default problem help please
ok my buddy has a built turbo gsr in his car and it was working perfect but now for some reason the battery keeps dieing when car is on and just stalling out we took the altinator out and got it checked out and it turned out perfect and the battery we got checked and its perfect as well but the battery is not geting a charge and somtimes the speedo stops working but doesnt throw a code and just befor the car dies the rpms drop to 0 but car is running for about 2 minutes befor it dies has this ever happend to anyone? please help
Old May 25, 2007 | 09:22 PM
lakai_19's Avatar
anyone?
Old May 25, 2007 | 09:45 PM
inspyral's Avatar
Some cars have a VSS/ALT fuse under the dash. I would check that first. I popped that fuse a couple years ago, and I went through 3 batteries and 2 alternators before I found it. My speedo would work intermittently and sometimes it would throw an ELD code.
Old May 25, 2007 | 10:04 PM
lakai_19's Avatar
awsome thanks i will give that a try tomorrow anyone elts?
Old May 26, 2007 | 07:43 AM
2redstars's Avatar
how did yo test the alternator? do this easy test, while the car is running, unhook the negative on the battery, if the car dies then it is the alt or something related to it. check your grounds and alt plug also
Old May 26, 2007 | 09:46 AM
lakai_19's Avatar
we took the altinator out and brought it to a shop and they tested it and said everything is good same with the battery but thanks i will try that
Old May 27, 2007 | 08:37 AM
lakai_19's Avatar
anyone elts?
Old May 27, 2007 | 08:45 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (lakai_19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakai_19 &raquo;</TD></TR><TR><TD CLASS="quote">anyone elts?</TD></TR></TABLE>
Just go check the fuse. Goddamn.
Old May 27, 2007 | 09:05 AM
95jeremie's Avatar
Default Re: problem help please (lakai_19)
did you check/ replace your wires?
if not do that they can corrode from the inside out
reset your ecu by pulling the fuse (prob won't work but it's worth a shot)
any one else I'm stumped
hook up a vid with sound
Old May 27, 2007 | 09:22 AM
lakai_19's Avatar
Default Re: (Archidictus)
did i say i havnt checked the fuse? and the only fuse i saw that had anything to do wiht the alt was good so chill goddamnnnnnnnnnnnnnn
Old May 27, 2007 | 09:23 AM
lakai_19's Avatar
Default Re: problem help please (95jeremie)
thanks for the info i will check that out
toader1704
Jan 22, 2010 05:29 PM
Si Jeff
Jan 11, 2009 10:57 AM
Si Jeff
27
Dec 20, 2005 05:34 PM
todapower
Feb 26, 2004 09:18 PM
shadowdawn
Oct 1, 2003 05:03 AM
