catch can q's lsvtec b18b1
Old Feb 10, 2006 | 07:38 PM
912's Avatar
912
Default catch can q's lsvtec b18b1
searched post on catch cans, i'm confused a bit when i run line from pcv to catch can do i eliminate the pcv valve or do i simply clamp hose on pcv then run to catch can, see i did lsvtec with b18b1 block with gsr head pcv vave just dangaling no where to put it
Old Feb 10, 2006 | 08:34 PM
JDM00SI's Avatar
Default Re: catch can q's lsvtec b18b1 (912)
depends on the kit
i got the endyn kit. Came with a plug to plug up where the PCV used to be.....
there are 2 fittings on ur block..... use an allen wrench to break those loose, put the endyn fittings in and the rest is pluig in play.
you can also route the cathcan from your valve cover, just 2 welded inserts/tubes
ther are alot of threads on ht on this.... SEARCH
Old Feb 10, 2006 | 09:26 PM
912's Avatar
912
Default Re: catch can q's lsvtec b18b1 (JDM00SI)
thanks that helped a lot, if i went the valve cover route where does my pcv go
Old Feb 11, 2006 | 07:47 AM
JDM00SI's Avatar
you can block it off....
thats what most people do, they plug up thier pcv ....
and route thier catchcan from the valve cover.
Old Feb 11, 2006 | 02:14 PM
912's Avatar
912
thanks
Old Feb 11, 2006 | 04:33 PM
91B16HF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">depends on the kit
ther are alot of threads on ht on this.... SEARCH</TD></TR></TABLE>Where did you get the kit at? Got a link?
Old Feb 12, 2006 | 05:27 PM
JDM00SI's Avatar
Default Re: catch can q's lsvtec b18b1 (91B16HF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91B16HF &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get the kit at? Got a link?</TD></TR></TABLE>
call larry from Endyn at 817 924 9334. really good guy...
tell him sam sent you.
Kompressorbengt
May 4, 2017 08:41 PM
likuidphreon
Feb 4, 2013 06:12 AM
TravisBiggie
Jun 23, 2012 07:40 PM
Nisif
46
Apr 18, 2008 03:49 AM
migs
22
Mar 26, 2008 05:23 PM
