Precision Turbo Advice
Old Sep 11, 2003 | 10:06 AM
drumking15's Avatar
Default Precision Turbo Advice
Currently i have a stock gsr block thats been rebuilt... i will be running a love fab mani w/a custom water/air intercooler setup...
I was lookinf for the best turbo to support 7psi as of now...and eventaully to support my 400whp goal in most likely a 83mm ge block w/ crowers and cp pistons....
what would your suggestions be...im shooting for a 5g spool up area...
spit you ideas my way...what size and a/r...i most likely want the .63 to keep the wheels from spining all day...
ideas on a similar setup and when you hit full boost would be greatly appreciated!
Old Sep 11, 2003 | 10:17 AM
redlinegsr's Avatar
Default Re: Precision Turbo Advice (drumking15)
I would recommend the sc34. Supports 500+ hp with "proper" tuning. Pm arturbo for more detailed specs. Good Luck
Old Sep 11, 2003 | 10:26 AM
Jared's Avatar
Look at the SC61 with an E housing as well. It should do really well at 7 psi as well as be capable of 500+ wheel horsepower when properly tuned.
Old Sep 11, 2003 | 02:12 PM
drumking15's Avatar
thanks guys...which one would have a faster spool time w/ there respective a/r's
Old Sep 11, 2003 | 02:15 PM
Drag_On's Avatar
34 will spool up a bit quicker but will not provide the ultimate power up top of the big dog 61.. There are turbos in the middle. Check precisions new web site..
Old Sep 11, 2003 | 02:17 PM
TurboTegB18c's Avatar
Default Re: (Drag_On)
sc61, spools at 4500rpm full boost at 5500. Paul
Old Sep 11, 2003 | 02:21 PM
drumking15's Avatar
paul...w/ what a/r and compressor cover etc?>?
Old Sep 11, 2003 | 02:58 PM
k20em2's Avatar
Default Re: Precision Turbo Advice (redlinegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend the sc34. Supports 500+ hp with "proper" tuning. Pm arturbo for more detailed specs. Good Luck</TD></TR></TABLE>
how much psi do you need to run on an sc34 to get 500hp? I had it on 15 psi and was only getting 290.
Old Sep 11, 2003 | 03:04 PM
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">paul...w/ what a/r and compressor cover etc?&gt;?</TD></TR></TABLE>
.63 a/r and the to4e compressor.
Old Sep 11, 2003 | 03:06 PM
Default Re: Precision Turbo Advice (k20em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20em2 &raquo;</TD></TR><TR><TD CLASS="quote">
how much psi do you need to run on an sc34 to get 500hp? I had it on 15 psi and was only getting 290.</TD></TR></TABLE>
I would honestly think it'll take about 30psi or so to make 500whp on the sc34. And you'll be way out of it's efficienty range.
Old Sep 11, 2003 | 03:10 PM
Charlie Moua's Avatar
Default Re: (TurboTegB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">sc61, spools at 4500rpm full boost at 5500. Paul</TD></TR></TABLE>
is that on a STOCK gsr cr and bore?
Old Sep 11, 2003 | 03:41 PM
quikB18B's Avatar
Default Re: (Charlie Moua)
Honestly the sc34 will be good for now whiile your running 7psi, but if your goal is 400 whp, i would go with something bigger . Tlak to art he can point you in the right direction. If i were you i woudl go with a .63 a/r and somehting slightly smaller than the sc61 if your looking for full boost @ 5k.
Old Sep 11, 2003 | 03:46 PM
MotorMatrix.com's Avatar
I am a bad person
I would suggest the sc61. the sc61 is one of the most efficient turbos ont he market right now. It make power at 6psi all the way to 30+. basically witht he sc61 you have a great low boost turbo with the option of being able to go up with the boost w/o having to change turbos.
Old Sep 11, 2003 | 03:47 PM
FredoSP's Avatar
SC50, Pm "Arturbo"
Old Sep 11, 2003 | 04:38 PM
EG6owner-T's Avatar
Default Re: (FredoSP)
i dont know which one i have but it could be the sc-50 which i like and supposely you can make 400+ whp with this turbo which I dont see how when I got the exducer at .48 which now I want to go with the same exact specs but with the exhaust at .63 like everyone else that gets good numbers.
i like mine on the ls since i hit full boost at 4k rpm.
no complains here boostin on a stock ls motor.
igotyofire's Avatar
is sc61 and 81mm bore b18c block a bad combo? far as speaking of lag? is the lag worth the power? or is a sc34 better, i mean like is it gonna lag so much that smaller turbo cars that reach full boost earlier might be compitition to keep up with?
Old Sep 11, 2003 | 06:48 PM
drumking15's Avatar
serisoly thanks guys for all the info....ne one got compressor maps on these bad boys..i googled it but came up short...
Old Sep 13, 2003 | 01:21 AM
igotyofire's Avatar
up
Old Sep 13, 2003 | 11:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
is that on a STOCK gsr cr and bore?</TD></TR></TABLE>
This is on 9:1 compression and 84mm bore, so with 10:1 compression, I would at least think it'll spool the same if not sooner. Paul
Old Sep 14, 2003 | 10:06 AM
downpipe's Avatar
i have an sc54 on my gsr with 10.0:1 comp., full-race mani and back-door intercooler. turbo begins to spool around 3000 and full boost hits around 4500, although i think this is more a result of a great manifold design (full-race ) since the sc54 is on the bigger side. sc54 supports up to around 620 hp, and precision tends to underrate their turbos.
Old Sep 14, 2003 | 10:37 AM
igotyofire's Avatar
Default Re: (downpipe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downpipe &raquo;</TD></TR><TR><TD CLASS="quote">i have an sc54 on my gsr with 10.0:1 comp., full-race mani and back-door intercooler. turbo begins to spool around 3000 and full boost hits around 4500, although i think this is more a result of a great manifold design (full-race ) since the sc54 is on the bigger side. sc54 supports up to around 620 hp, and precision tends to underrate their turbos. </TD></TR></TABLE>
and what kinda numbers r u making now with what boost?
Old Sep 14, 2003 | 11:04 AM
AMS MIKE's Avatar
Default Re: (igotyofire)
GT3040R by HKS...ball bearing
Old Sep 14, 2003 | 07:45 PM
downpipe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">
and what kinda numbers r u making now with what boost?</TD></TR></TABLE>
only street tuned to 9 psi so far. once we hit the dyno i'll post it up.
h-duced
Feb 24, 2008 07:52 PM
salsero_utah
Nov 13, 2005 05:03 PM
unknown0304
Jun 7, 2004 12:33 AM
E-spec Tuner
Nov 5, 2003 05:58 AM
Bulldogg83
Oct 15, 2003 11:06 PM
