turbo options for 600whp
Old Jun 6, 2004 | 10:48 PM
unknown0304's Avatar
Default turbo options for 600whp
what are my options for a turbo that can supprt 600+whp
this is going on a street car(not a daily driver)(stock bore b18c5)
i was thinking a T04X or a full-race t4/t67
any suggestions and yes i tried searching
-will
Old Jun 6, 2004 | 11:12 PM
TurboLSVtecTeg's Avatar
Default Re: turbo options for 600whp (unknown0304)
You have alot more to do then figure out what turbo your going to run if you plan on hitting 600whp out of a stock bore C5 Block.
Old Jun 6, 2004 | 11:18 PM
r cleghorn's Avatar
my favorite is our T3/T67...that's what i would suggest. It will have better response and spool quicker for a street car...especially with stock bore. and it will still support 600 hp.
turbolsvtecteg is correct you do have more to consider than just the turbo...what are your plans?
give us a call at the shop if you have any questions 866-FULL-RACE
Old Jun 6, 2004 | 11:35 PM
SOUNDEFFECTS's Avatar
Anyone tell me what are the specs of a TO4x?
Old Jun 6, 2004 | 11:42 PM
oscarmayer's Avatar
Extremely vaig question w/o major details on your setup. there are SO many options depending on setup. But I think your not going to egt 600 out of a stock bored C5 easly. There just isn't enough flow atstock, your most likley going to have to sleeve it and punch it to a 2 liter.
Old Jun 7, 2004 | 12:33 AM
Default Re: turbo options for 600whp (oscarmayer)
Not including, fuel setup, tranny and drivetrain mods, engine management, suspension, there are so many things I really dont even know where to start.
But I guess if you just want to know what turbo will support 600+whp. You have all the other parts figured out. The turbo setup should be one of the last parts of your build.
But the T3/T67 from full-race is a good turbo for 500-600+whp. I do know you can get a precision PT67 with a T3 Turbine housing. Now which one between the two is better I dont know. I dont think ive ever seen anyone with a T3 Housing PT67. But it can be done with a T3 housing. The T4 would have way to much lag. You would need to spray off the line to get any kind of boost in first gear let alone a decent amount in second.
b18bEKcoupe
Jun 15, 2007 12:36 PM
Samuels
Apr 16, 2007 05:38 PM
gezer
May 23, 2003 02:54 PM
00ITR725
Mar 27, 2003 08:30 PM
