How much hp can you get from a precision SC6031?
I got a precision SC6031 turbo. I want to know if you guys think this is a good turbo for my setup. How much hp can I get out of this turbo. This is the first time that im doing a turbo build. Its going on my fully bulit H series with STOCK sleeves. And i know someone is gonna try to say you can run after market pistons in a stock sleeve. But just to let you know I got Mahle 9:1 pistons
Moderator
Re: How much hp can you get from a precision SC6031? (h-duced)
That is comparable to a 60-1 with a stageIII turbine wheel in a an E-Cover, T31 Precision turbine housing. It's about 480-500whp max or so. But it does not like anything over 24psi for that particular compressor wheel.
Hey wass up bro THat build sounds like it gonna do some damage. Chck out this h22 turbo build up in my town. If the mahle can hold up. to boost I thins we can all get close to theses kinds of power without the sleeving, with good tunes.... http://www.tunedbylorange.com/shopcar.html http://www.tunedbylorange.com/shopcar.html Here check out this website
