precision injectors
Old Nov 13, 2003 | 06:24 PM
DubyaAye's Avatar
Default precision injectors
does the precision injectors suppose to plug right into the the plugs on the motor. i try searching but cant find anything. reason i asked cause mine doesnt plugs in all the way.
Old Nov 13, 2003 | 06:40 PM
omahaturbocivic's Avatar
Default Re: precision injectors (DubyaAye)
They worked for me with the obd0 clips. For obd1 there might be a notch on the inside that has to be cut out like the dsms, I dont remember did not look at them that close when i installed them since they plugged right in for me.
Old Nov 13, 2003 | 07:53 PM
boostaholic's Avatar
Default Re: precision injectors (omahaturbocivic)
They should work with obd0 or obd1 injector clips, but no OBD2.
Old Nov 14, 2003 | 12:03 AM
DubyaAye's Avatar
Default Re: precision injectors (boostaholic)
but i have obd1 motor.
Old Nov 14, 2003 | 05:45 AM
b18bturbo's Avatar
some of the obd 1 injectors have tab inside that you will have to remove. its little tab inside the injector some obd 1 and 0 fit fien and others dont.
killerpenguin21
May 2, 2010 11:51 AM
CRX44
Aug 31, 2009 11:13 PM
AmauryR
Nov 15, 2007 09:46 AM
e jay one
Sep 10, 2005 09:15 AM
CaptinMcnut
Mar 1, 2004 02:01 PM
