-8 vs -10 for oil return
Old Sep 23, 2009 | 06:12 PM
cpl rampage's Avatar
Default -8 vs -10 for oil return
Ok, so right now i have a steathmode performance oil return kit on my Garrett T3/t4. works ok, but a lil prone to leaking, and not the greatest peice of mind.... i am pulling the engine this winter to redo the Dp, and i was going to upgrade to AN fittings. now i know i am currently using -10 hose from the steathmode kit. My frind has alot of -8 line and fittings left over from one of his projects and i think he might have everything i need to make a return, and i can get it for a great price. now the question is, is it safe for the turbo to run a -8 line? it is a journal type cartridge, and it has a -3 feed line, with no restrictor. Let me know what you think/what are your experiences. Thanks
Old Sep 23, 2009 | 06:38 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: -8 vs -10 for oil return
1/2" will work just fine (it does for me)... you can't go wrong with the 5/8" either or bigger for that matter.
Old Sep 23, 2009 | 08:15 PM
TheShodan's Avatar
Moderator
-10AN is to be used for your Journal bearing Garrett. stick with that.
Old Sep 24, 2009 | 04:38 AM
Thank you!
Old Sep 24, 2009 | 06:49 AM
Autoworks's Avatar
Agreed, you do NOT want to go down in your drain size.
crvtkllr
Sep 21, 2006 02:57 PM
RNPoo7
Aug 5, 2005 06:44 PM
r7
Jul 10, 2003 12:15 PM
Acura_I-RS
Mar 9, 2003 09:59 PM
sushibug
Mar 30, 2002 10:11 PM
