Deltagate 3-5 psi spring + MBC ?
Old Jun 4, 2002 | 07:38 AM
X2BOARD's Avatar
Default Deltagate 3-5 psi spring + MBC ?
What is the downside to switching from a higher resistance spring on a deltagate WG... like the 5-7 psi spring and going to the 3-5 psi spring ? I am running a turbonetics MBC and my intention is to run the 3-5 psi spring and be able to adjust from the minimum 3-5 on up to whereever.... 8, 9, 12... whatever.
Would the 3-5 psi spring + MBC be able to fuel my needs ?
Old Jun 4, 2002 | 07:55 AM
CovertFI's Avatar
Default Re: Deltagate 3-5 psi spring + MBC ? (X2BOARD)
yes
dont know of any down sides
Old Jun 4, 2002 | 08:07 AM
X2BOARD's Avatar
Default Re: Deltagate 3-5 psi spring + MBC ? (CovertFI)
Downsides.... maybe the WG can't reach it's max. pressure and hold it because of the softer spring ??
Old Jun 4, 2002 | 08:15 AM
Cramerox's Avatar
i think you should be ok. the MBC will fool the wg so it will stay open to what ever psi u set it at. Its just bascially bleeding air.
Old Jun 4, 2002 | 08:20 AM
X2BOARD's Avatar
Default Re: Deltagate 3-5 psi spring + MBC ? (Cramerox)
Thanks fellas... I'll roll over to Dynamic Turbo on lunch and pick up the 3-5 spring.
high_octane
Oct 12, 2007 02:58 AM
t-powersi
Apr 29, 2007 08:02 AM
EJ8 GSR-T
Mar 14, 2007 12:17 PM
Bimmerman
May 7, 2005 06:45 PM
Short Round
Nov 12, 2003 10:16 PM
