Possible to turbo a DPFI?
Old Jul 24, 2008 | 04:53 PM
kenoshaGSR's Avatar
Default Possible to turbo a DPFI?
Noob question, but im not sure. i have a stock d15b2 (DPFI)
But i was wonderin if you can still boost them and be safe?
any information would be great
thanks
Old Jul 24, 2008 | 04:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Possible to turbo a DPFI? (kenoshaGSR)
you can.
how do you propose handling the fueling needs?
you only have 2 injectors.
Old Jul 24, 2008 | 05:07 PM
Turbo O's Avatar
Default Re: Possible to turbo a DPFI? (boostedcivicsir)
you can boost it. it just wont be as reliable.
so you best bet is to go mpfi and then turbo it.
Old Jul 24, 2008 | 11:09 PM
CRXdan's Avatar
http://www.homemadeturbo.com/turbo_projects/d15b2/
Old Jul 25, 2008 | 02:52 AM
Mr. Badwrench
Default Re: Possible to turbo a DPFI? (CRXdan)
You can see 1 of the 2 injectors that are plumbed in the charge pipe before the throttle body. Controlled by SDS.
not just relying on the 2 stock injestors.
at this point, swapping to mpfi and having better tunability would be just as much.
Old Jul 25, 2008 | 03:14 AM
ptftw's Avatar
x2 just go mpfi
Old Aug 5, 2008 | 10:10 PM
1990si's Avatar
Default Re: Possible to turbo a DPFI? (ptftw)
its been done before. but not recomended. you will have a very hard time getting enough fuel. i would just convert to mpfi you can do it for a couple hundred bucks.
jestin91
Feb 10, 2013 08:40 AM
range hadies
Mar 12, 2012 10:42 PM
gsxrallday
Oct 3, 2007 12:54 PM
civintegra
Jul 17, 2007 12:31 PM
wrXtian
10
Sep 17, 2002 08:09 PM
