Gsr turbo boost question
Old Jul 16, 2007 | 08:43 PM
civintegra's Avatar
Default Gsr turbo boost question
i dont like to post unless i cant find the answer to my questions (couldnt find this). I have a an ek with b18c1 swap. I am almost finished with my turbo install, and wanted to know how much boost i cant push safely on the stock injectors. I have 9:1 JE pistons, stock injectors are 240cc i believe. i also wanted to know how much advance on my timing i should have any help would be greatly appreciated. i dont want to push it to much as i will be ordering bigger injectors as soon as i decide on what to get.
Old Jul 16, 2007 | 09:09 PM
djtrini's Avatar
Default Re: Gsr turbo boost question (civintegra)
keep stock injectors and dont go into boost! safest way really! unless you want to run around 55-60 psi of fuel incase u get the itch to go into boost!
Old Jul 16, 2007 | 09:12 PM
DecentCivicZ6's Avatar
B A N N E D
Default Re: Gsr turbo boost question (djtrini)
stock injectors....like 5-6psi..depending on turbo size....but im guessing you have a stock ecu also?? if so, all you are going to do is throw CEL and engine will run like **** on boost. you need a chipped ecu and have it street tuned atleast. unless you wanna run around with CEL spitting and sputtering on boost.
Old Jul 16, 2007 | 09:21 PM
1Quikgsr's Avatar
i would suggest you upgrade to some 550cc or some 750s you can get them for like 200-300 and also get hondata
Old Jul 16, 2007 | 09:34 PM
civintegra's Avatar
well not turbocharging is not an option the whole motor is built around it. I was thinking 750cc cause thats the biggest i can find saturated, and i dont want to mess with resistors. i figured about 5 lbs until i get upgraded fuel system and ecu.
Old Jul 16, 2007 | 09:35 PM
civintegra's Avatar
Default Re: (1Quikgsr)
if i get hondata do i need to do anything else to the ecu? i mean do i still have to chip the ecu?
Old Jul 16, 2007 | 09:39 PM
civintegra's Avatar
am i doing any damage though when the cel comes on?
Modified by civintegra at 11:59 PM 7/16/2007
Old Jul 16, 2007 | 11:00 PM
civintegra's Avatar
b
Old Jul 16, 2007 | 11:08 PM
Schister66's Avatar
Man U FTW
built engine and stock injectors....good plan
stay out of boost or you may as well throw that engine away now
Old Jul 16, 2007 | 11:09 PM
Chris Tune's Avatar
Default Re: (Schister66)
yeah hell of a plan... dont go into boost with stock ecu EVER.... please u will need a hack... thats so 80's...
Old Jul 16, 2007 | 11:14 PM
civintegra's Avatar
okay so no on driving until ecu and fuel i was under the impression stock ecu/ injectors could handle a little boost. ill look into getting both on their way. thanks for the help
Old Jul 16, 2007 | 11:20 PM
Schister66's Avatar
Man U FTW
stock fuel system and ecu can handle normal driving, but i would NEVER under ANY circumstances get into boost....if you can't stay out of the gas, you may as well pull that engine and send it to me....i'll return a box of metal shavings and a few F'd pistons in return
Old Jul 16, 2007 | 11:37 PM
civintegra's Avatar
got it thanks for the info, i know i should not drive it but its hard when its just sitting there ..lol i will wait a week or so get an ecu, fuel delivery and try and find a tuner in utah anyone know of someone
Old Jul 17, 2007 | 04:58 AM
Schister66's Avatar
Man U FTW
look in here
https://honda-tech.com/zerothread/1347699
Old Jul 17, 2007 | 06:11 AM
HiProfile's Avatar
I'm running a small turbo on a D16 @ 11:1 afr's, and the stock 240's would max out at 4psi when I scale the map back to them (and it was afr tuned at every parts change, so I'm not just guessing). 240's are good for ~180whp NA, ~160 turbo, which is like 1psi on a small turbo for a GSR.
Seeing as how any capible tuner can get 1000cc injectors to idle fine, just get anything 750cc-1000cc now and you'll be fine for at least 500whp.
Old Jul 17, 2007 | 11:59 AM
civintegra's Avatar
okay i got injector on thier way as well as a walbro fuel pump. now..... how much boost can i push before i upgrade the ecu situation. i was up late last night looking into all my options and there is to much information to make a quick decision.
Old Jul 17, 2007 | 12:17 PM
CoreyR's Avatar
Default Re: (civintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civintegra &raquo;</TD></TR><TR><TD CLASS="quote">okay i got injector on thier way as well as a walbro fuel pump. now..... how much boost can i push before i upgrade the ecu situation. i was up late last night looking into all my options and there is to much information to make a quick decision. </TD></TR></TABLE>
did you not read all the replies? the ECU CANT read boost in stock form. and youll absolutley not be able to drive around on larger injectors with the stock ECU.
honestly if your not going to do it right, dont do it at all.
Old Jul 17, 2007 | 12:31 PM
patrick4588's Avatar
check out this. http://www.jkobd.com. he did my ecu for me. great guy and knows what he is doing!
Djbigwill
Jul 12, 2013 04:44 AM
r1ch1e
Sep 12, 2008 10:46 AM
ketchup!
Sep 9, 2006 07:42 PM
hondadragon
Jul 5, 2004 01:12 PM
MysteriousGSR
Feb 10, 2003 07:56 PM
