is it possible to rotate the 14b compressor housing?
Old Feb 24, 2004 | 04:58 PM
Tad's Avatar
Tad
Default is it possible to rotate the 14b compressor housing?
Hi,
i've got a 14b and the compressor outlet aims up currently,
i'm thinking about setting it to aim down, but not sure if I can.
I dont have anything to take off the circlip, so I havent had a chance to see if its possible.
But i'm thinking, wouldnt rotating it mess up the positioning of the wastegate actuator?
just wondering,
thanks.
Old Feb 24, 2004 | 07:01 PM
IN VTEC's Avatar
Default Re: is it possible to rotate the 14b compressor housing? (Tad)
We've tried it before to get before positioning for the oil feed and coolant lines, but the wastegate actuator arm didn't wanna line up straight with the housings clocked differently.
Old Feb 24, 2004 | 09:33 PM
lazerus's Avatar
Default Re: is it possible to rotate the 14b compressor housing? (IN VTEC)
its not a problem if you can weld aluminum and have a tap/die set and biiig circlip pliers :-)
Old Feb 24, 2004 | 09:56 PM
Tad's Avatar
Tad
Default Re: is it possible to rotate the 14b compressor housing? (lazerus)
heh.. guess i'll just have to leave it aiming up then,
o wel
worx
Feb 9, 2010 07:23 AM
G_moneydc2
Apr 22, 2006 01:16 PM
turbochargeb18c
Sep 5, 2005 08:36 PM
BoostedD15B7
Dec 8, 2002 05:30 PM
Smoothy
Oct 26, 2001 12:22 AM
