Turbo for my d16y7
Turbo for my d16y7
its too big ? for a 6psi setup
A number of compressor and turbine options are available all featuring excellent map width,pressure ratio and efficiency.
Enhanced durability compressors are available.
Standard Features
* Choice of turbine housing materials to cover a wide range of temperatures.
* Compressor and turbine wheels selected for optimum airflow, efficiency and pressure ratio.
* Fully adjustable compressor and turbine housing orientation.
* Fully floating twin hydrodynamic journal bearings.
* High efficiency compressors with broad operating ranges.
* High pressure ratio capability.
* Superback compressor wheels for extended life and durability at high turbo speeds.
* Symmetrical twin flow turbine housings.
* Variety of compressor and turbine housing flanges available.
Optional Features
* CNG Engine version.
* MWE (Map Width Enhancement) compressor inlet.
* Sound suppression baffles.
* Watercooled bearing housings.
Dimensions HX35
Length mm 224
Width mm 250
Height mm 169
Smallest Mass kg 9
Largest Mass kg 11
Airflow kg/s 0.46
Standard Features
Optional Features
Dimensions HX35
Length mm 224
Width mm 250
Height mm 169
Smallest Mass kg 9
Largest Mass kg 11
Airflow kg/s 0.46
Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">T4 turbine on that bitch? Keep it far away from a SOHC...</TD></TR></TABLE>
MrBond
08-15-2004 01:15 PM
