Possible problem please look!!!
Old Feb 2, 2004 | 09:09 AM
integracivic94's Avatar
Default Possible problem please look!!!
Just bought a turbo for my civic from a junkyard! i spun the turbine with my fingers and it spins fine but as soon as i stop spinning so does the turbine! i thought they was supposed to keep spinning??? is this right! by the way there is no shaft play! i think its a t3 a.r48
Old Feb 2, 2004 | 09:21 AM
Default Re: Possible problem please look!!! (integracivic94)
bump it up
Old Feb 2, 2004 | 09:23 AM
b18bturbo's Avatar
as long as it doenst have any shaft play in and out and up and down you should be oaky.
Old Feb 2, 2004 | 09:33 AM
Default Re: Possible problem please look!!! (b18bturbo)
nah has none at all! has a tiny little hairline crack under the turbine where the downpipe bolts up but apart from that the rest is fine! might just be sticky from where it has'nt been used for a while!!!
Old Feb 2, 2004 | 09:46 AM
Bailhatch's Avatar
ya they tend to loosen up once you use it. if you put a cap full of oil in the oil inlet and spin it with your funger it might get smoother and it should help keep it from sticking if your not going to install it for a while. It should have a little side to side play btw maybe the thickness of a businesss card depending on the turbo.
Old Feb 2, 2004 | 11:10 AM
Default Re: Possible problem please look!!! (Bailhatch)
Thanks for the advice really appreciate any help and the time taken to read and reply! thanks
Old Feb 2, 2004 | 11:32 AM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Just bought a turbo for my civic from a junkyard! i spun the turbine with my fingers and it spins fine but as soon as i stop spinning so does the turbine! i thought they was supposed to keep spinning??? is this right! by the way there is no shaft play! i think its a t3 a.r48 </TD></TR></TABLE>
if i understand your problem right - you are confused the turbine and compressor wheel are affixed to a shaft they rotate together.
Old Feb 2, 2004 | 11:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Possible problem please look!!! (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">
if i understand your problem right - you are confused the turbine and compressor wheel are affixed to a shaft they rotate together.</TD></TR></TABLE>
I believe he meant to say that when he stops spinning the wheel, it doesn't keep spinning on it's own, as if it were riding on some new ball bearings.
Old Feb 2, 2004 | 11:41 AM
Default Re: Possible problem please look!!! (DaX)
yeh
dam thing posted before i finished! thats what i was trying to say
lsvtec_hatchback
May 27, 2012 04:06 AM
JDMeg95
Dec 12, 2007 12:40 AM
ZEXGS-R
Mar 26, 2005 06:01 AM
dturbo
Feb 16, 2005 05:45 PM
Civic driven01
Feb 14, 2005 03:50 PM
