is this possible???
Old Jun 20, 2005 | 06:11 PM
deemack79's Avatar
From: The Burbs of NYC, where you can park your car on the street & they wont steal it NY
Default is this possible???
can i boost my sohc with about 10.9 to 1 comp. and how much boost can i run(only looking for about 6-7 lbs max) the motor is semi built with a fully balanced rotating assembly and shot peened rods with arp rod and head bolts. this motor has held up to 100 shot of the juice......
just a shot in the dark
Old Jun 20, 2005 | 06:41 PM
HXMan's Avatar
Default Re: is this possible??? (deemack79)
I'm running a stock compression GSR engine with 10 lbs of boost on a t3/to4e.....id say you will be fine with 6-7 psi, or more.
Old Jun 20, 2005 | 06:54 PM
Jcup315's Avatar
dido...your good for more than 7psi if you want
Old Jun 21, 2005 | 02:05 PM
7k rdlne's Avatar
Default Re: is this possible??? (Jcup315)
its all in the tune
Old Jun 21, 2005 | 03:55 PM
deemack79's Avatar
Default Re: is this possible??? (7k rdlne)
thanx 4 the input guys..
Old Jun 21, 2005 | 05:33 PM
11psiTurboSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7k rdlne &raquo;</TD></TR><TR><TD CLASS="quote">its all in the tune</TD></TR></TABLE>
Yup!
Old Jun 21, 2005 | 06:30 PM
b16hybridsol's Avatar
Default Re: is this possible??? (11psiTurboSI)
be careful with your timing and fuel at that compression level
one slow coupe
Mar 19, 2006 05:52 PM
ATS*Mark
Oct 23, 2005 10:51 AM
civiwhip
Jun 23, 2005 12:25 PM
deemack79
Feb 14, 2005 05:33 PM
dunkd
Nov 12, 2003 08:10 PM
