poor idle on b18c turbo ITR on ectune
i have a fully built jdm ITR which is turbo'd running on ectune. and im having issues with the idle speed..
its been set to 1100rpm through the ectune, and sometimes it does idle at 1100rpm but very rarely.. alot of the time it sits at 2k - 2.5rpm and then drops to 1.5k rpm after a little while, but sometimes when i start the car it barely ticks over and idles at around 200rpm and usually cuts out..
ive replaced the idle control valve.. if i pull the plug on and off whilst the engine is running and the idle is around 200rpm, it makes the idle go back up to around 1.5k rpm. sometimes it behaves itself, sometimes goes back down to 200-500 rpm after a drive up the road..
im just wondering if it could be a dodgy TPS?
your thoughts apreciated - dan
Re: poor idle on b18c turbo ITR on ectune
yes its tuned, the strange thing is it was idleing fine the first time it was mapped but the turbo failed (oil restrictor too small)
replaced the turbo with the exact same model, and since then its had this problem, and it was mapped with this new turbo aswell..
i have not checked the TPS yet..
ive checked for vac leaks etc
Here's how to adjust your tps fella:
How to adjust your TPS if it is reading incorrect voltage:
-Get a volt meter, digital or analog.
-loosen screws that attach TPS to TB. (you may need to take a dremel and make a slot in each screw for a flathead, because USDM TB's have breakaway bolts instead of torque spit bolts)
-turn key to ignition.
-attach voltmeter to middle PIN on the harness and slowly rotate the TPS until the desired voltage is reached. (in this case, between 0.45-0.50 volts)
-tighten down screws finger tight and test for correct voltage at 0 throttle and at WOT (WOT = 4.45 or higher).
-if voltage is correct, tighten down screws, but not too tight or you will crack your TPS.
-turn on car and you should have a perfectly working TPS. You may need to readjust your idle if you messed with it while trying to figure out your original problem, like me.
This method saves the hassle of taking off the TB (not much of a hassle...but ya).
both my cars do that on ectune too? my turbo one just started doing it but it runs prefectly fine and everything? idk
In my experience, ectune idles practically anything, and does it better than any other EMS. However if you have a vac leak or a an internal engine issue, it will go bonkers trying to hunt for that RPM.
One question I have is how you have base idle set. Meaning does it idle around 500-750rpm with the IACV unplugged? With a regular 750 rpm idle, it should be 400 rpm base, so the base idle should be about half the regulated idle.
ok guys just want to update this problem..
so i took the car back to my mapper, we hooked up the laptop and went about adjusting the idle via the software, moving it up and down on the software the rev's were not responding..
so we took the
idle control valve off of an ITR that was sitting in the workshop that was known to work properly.. we fitted this and went to adjust on the laptop, the revs were now responding when adjsusting it via ectune, so i thought great its fixed...
drove 5 secs down the road and when i put the clutch down she cuts out... anyways i said id give it a try for a week and see how i get on..
a week later... so its been doing the same thing as before all week, most of the time it idles at 1500rpm to 2500rpm, after driving for a while it usually drops to around 1100 to 1500rpm but thats not always the case..
yesterday started it up from warm and it was idling at around 800rpm, i opened the hood and unplugged the idle control valve whilst the car was running, then plugged it back on and the idle shot back up to 1500rpm and stayed around that for the rest of the evening..
it really does have a mind of its own..
sometimes it doesnt seem like its working at all.. this morning i started it up and its idling at 800rpm..
so we took the
also just to point out, we checked the voltages at the idle control valve connector and compared it with the ITR in the workshop and they were the same, so we know the wire is good.
we even plugged the ectune into the ITR in the workshop to test the ectune was working correctly with the idle control which it was..
so far we have gathered that
the ectune is functioning correctly
the idle control valve works
the idle control valve wiring is good
we also check the TPS readings via the ectune and that appears to be opperating correctly too..
are there any other sensors that the idle control valve relie's on to operate correctly?
ok just started her up from cold..
idle is around 800rpm almost stalling..
open the hood, unplugged the idle control then plugged it back again and idle went up to around 1500rpm..
turned engine off... restarted.. idle at 800rpm again.. unplugged idle control and re plugged, idle goes back to 1500rpm..
turned engine off, restarted.. and the same thing..
hmmm.. map sensor is brand new omni 4bar, TPS was functioning correctly according to my mapper.
ive check all the vac pipes aswell but no leaks that i can see... plus if there was a leak you would think the idle would be high all the time, but it does idle at 800rpm alot so that kinda makes a vac leak unlikely.
I had a similar issue with my itr....iacv valve pretty much died...it wouldnt hold idle on while cold.
