single cam boost need help
Old Sep 17, 2009 | 08:02 AM
ekjoker's Avatar
Default single cam boost need help
just got a ekhatch with a 1.5single cam non vtec i wanted to boost for a daily driver just like 10pounds on stock blocks.. what do i need so it can be reliable? i was thinking some piston and rods headers and intake... some help would be good.. thanks
Old Sep 17, 2009 | 08:06 AM
kyden's Avatar
Default Re: single cam boost need help
header and intake with turbo? you need to do some more research.
Old Sep 17, 2009 | 08:08 AM
EdGe(161)'s Avatar
+++++++1 thank god he came here instead of homemadeturbo lmfao
Old Sep 17, 2009 | 08:24 AM
ekjoker's Avatar
what do i need to do to make a reliable for a dialy driver on 10pounds of boost?
Old Sep 17, 2009 | 08:52 AM
gottalovethe4door's Avatar
you need to have a good running motor... no oil leaks, good compresion, etc. a good tune up: plugs, wires, maybe timing belt and water pump... after this is done, an upgraded clutch might be a good idea, but not completely neccesary.... maybe get the greddy base kit with or without the intercooler, a high flow cat and a 2.5" cat back exhaust... also install a lower tempature thermostat...
Old Sep 17, 2009 | 08:55 AM
i think that kit puts out like 6 lbs of boost... you can always tune/upgrade from there... but even at 6lbs the diffrence from stock will seem like night and day...
Old Sep 17, 2009 | 10:42 AM
ekjoker's Avatar
6pounds is good enough for me for a daily driver..
Old Sep 17, 2009 | 11:04 AM
yeah no doubt... plus greddy kit has e-manage or whatever.... no tuning really just plug in and go... no headers required ;-)
Old Sep 20, 2009 | 06:17 AM
Autoworks's Avatar
"10 pounds" doesnt mean much alone. 10psi on a IHI rhb5 or 10psi on a SC61?
How much power are you looking to make in you sohc dd? The relaibility is going to be in the tune, motor condition, and parts quality. There is a SOHC thrread in here somewhere, you may also want to check out d-series org and turbod16. Do some researching around there.
Old Sep 20, 2009 | 09:34 AM
Psychoteen101's Avatar
You need to throw that motor in the dumpster and get something different.
No 1.5 non vtec motor is safe for boost, the rods are about the thickness of your pointer finger.
Old Sep 20, 2009 | 12:40 PM
willyboyK20's Avatar
wait a sec, how do you have a ek hatch with a 1.5 in it? Was there an older engine swapped in there before you got it because all 96-00 "EK" hatches come with the d16y7 which is a 1.6 liter. Granted those rods aren't as beefy as its dohc cousins but its not much different then the y8 rods. I boosted my y8 for about 3 years now at 240whp.
I think you may have gotten the short end of that deal. What does the engine code say on the front of the engine?
ilovemyh22
Mar 28, 2009 06:48 AM
HondaH22a#1
Jun 16, 2008 08:07 PM
DasaEJ1
Apr 9, 2005 10:50 AM
Shakes
Jan 16, 2003 01:33 PM
JalopySiR
Jun 8, 2002 08:25 AM
