plx m500
Old Jun 18, 2004 | 11:50 AM
infra's Avatar
Default plx m500
My plx m-500 unit is showing 14.6-14.7 always ..
i have hooked it up as the instructions says.
and replaced the stock narrow o2 with the wo2 and narrow output
i know the car is running rich.. any knows what the problem could be?
thanks
Old Jun 18, 2004 | 01:13 PM
infra's Avatar
Default Re: plx m500 (infra)
just noticed that my idle rpm is 1200 instead of 750-800
allthough its steady.
any clues?
Old Jun 18, 2004 | 10:26 PM
infra's Avatar
bump
Old Jun 18, 2004 | 10:51 PM
warrick's Avatar
recalibrate? double checked that the settings you have are correct?
where is the sensor?
Old Jun 19, 2004 | 03:30 AM
infra's Avatar
Default Re: plx m500 (warric_k)
its self calibrating and theres no settings to change..
its in my downpipe, replaced my narrow o2 sensor...
Old Jun 19, 2004 | 10:29 AM
infra's Avatar
problem solved.. found that one wire was cut behind the protective plastic...
Old Sep 20, 2004 | 10:29 AM
XDEep's Avatar
why was it cut?
how do you like the unit so far?
groupbuy anyone cheapest ive found it for is $469 from http://www.urdusa.com/Merchant..._Code=
Old Oct 5, 2004 | 07:42 PM
XDEep's Avatar
Default Re: plx m500 (XDEep)
well i got mine and im not getting an AFR signal from the controller through wireless to the notebook. it sends rpm from the datalogging inputs through wireless, just not AFR. controller displays AFR fine. narrowband and wideband outputs work fine.
i'm not supposed to hook the wideband output and loop it back into the analog input am i? the instructions dont say you need to do this.
Old Oct 5, 2004 | 11:25 PM
eddyboy's Avatar
Unfortunatly I believe you have to.
I have the same wideband and couldn't get my afr to log as well. I haven't confirmed this through anyone plx though. I remembered reading it in another post. My car is down right now so I can't really test it. But if you find out please let me know.
Thanks
Ed
Old Oct 5, 2004 | 11:33 PM
eddyboy's Avatar
Default Re: plx m500 (eddyboy)
I just looked up PLX website.
It looks like you are correct you do have to take you wideband output and feed it back into a analog input.
http://www.plxdevices.com/M-Se...o.htm
If you look at where they tell what signals you can datalog, you will see
PLX WIDEBAND AIR/FUEL RATIO - In RED identifying it as a Analog Input.
crxaddikt
Feb 4, 2013 04:02 AM
tuname420
Engine Management and Tuning
Sep 15, 2008 12:37 AM
ABCVTEC
May 22, 2007 12:37 AM
preyluda
Feb 9, 2007 10:28 PM
jdmls88
Sep 30, 2006 10:36 AM
