Plugs are pitch black
Old Sep 8, 2004 | 03:55 PM
MooreBoost's Avatar
Default Plugs are pitch black
I pulled my plugs and theyre pitch black and have build up on them. Im running a 12:1 AFR under boost, and ~14:1 at idle. I know youre supposed to run 12:1 but Im not sure if my plugs are supposed to be this black / covered in crap.
Old Sep 8, 2004 | 04:13 PM
Tad's Avatar
Tad
what do you mean buildup?
if your running rich your plugs are gona be black,
and you want to run rich to be on the safe side..
but I duno about there being chunks or something on em!!
Old Sep 8, 2004 | 04:38 PM
MooreBoost's Avatar
Default Re: (Tad)
Theyre not chunky, but fuzzy looking. Its not a soft buildup, I had to use a wire brush to get them clean.
Old Sep 8, 2004 | 04:45 PM
Tad's Avatar
Tad
Default Re: (tegunderpressure)
well whats all ur specs,
injectors, what ur using for tuning fuel management,
what timing are you running, etc?
Old Sep 8, 2004 | 04:48 PM
MooreBoost's Avatar
Default Re: (Tad)
DSM 450s
AFC hack and BTM
Im unsure of the timing to be honest.
Old Sep 8, 2004 | 06:16 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">
AFC hack </TD></TR></TABLE>
there lies your problem
Old Sep 8, 2004 | 06:19 PM
beepy's Avatar
Default Re: (Mase)
Not nessessarily.
Are you tuning with a wideband?
Old Sep 8, 2004 | 06:21 PM
Mase's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Not nessessarily.
Are you tuning with a wideband?</TD></TR></TABLE>
i would assume so since he stated he was running 12:1 in boost and 14:1 at idle...
Old Sep 8, 2004 | 06:23 PM
MooreBoost's Avatar
Default Re: (Mase)
Yes I am tuning with a w/b.
Are you just knocking the hack in general or can it actually cause a problem with build up on plugs?
Old Sep 22, 2004 | 08:12 PM
EKhothatch's Avatar
My plugs are pitch black and I'm also wondering what variables can cause that. The car also bogs bad and cuts complete out with the crack of the throttle. Also my fuel pressure is pretty high. At or above 70-80psi.
Old Sep 22, 2004 | 08:23 PM
SleeperGTP's Avatar
Default Re: (EKhothatch)
Bad fuel filter maybe?
Old Sep 22, 2004 | 08:39 PM
EKhothatch's Avatar
Default Re: (SleeperGTP)
You know, that did pop into my mind just earlier. Although, I'll highly doubt it. I will check.
Old Sep 22, 2004 | 08:52 PM
SleeperGTP's Avatar
Just trying to help out
Old Sep 22, 2004 | 09:20 PM
adeihl's Avatar
Nahh... what range are you running.. Sounds to me like they are not cleaning.... 1350 degrees is self cleaning temp...
your plugs should be from 800-1350 for "normal" life try going a step hotter..
Old Sep 23, 2004 | 05:20 AM
EKhothatch's Avatar
Default Re: (adeihl)
Both the stock plugs and BKR7Es do the exact samething. Run completely black. The runs like complete crap. Any hard adjustment of the throttle and wants to kill itself and floods. I'm still wondering how the hell my FP when up to 70-80psi. I will try some other FPR but could it be anything else?
M2B4
Jul 30, 2007 09:37 PM
bennyhonda7
May 26, 2005 05:32 PM
Layziebtnh055
Aug 23, 2004 05:06 PM
SOFLSOL
Sep 17, 2003 07:47 PM
SOFLSOL
Sep 12, 2003 12:19 PM
