please te04h
Old Mar 30, 2004 | 05:51 PM
FAST AS's Avatar
Default please te04h
i have a te04h need info please please
Old Mar 30, 2004 | 06:48 PM
FAST AS's Avatar
Default Re: please te04h (FAST AS)
please please
Old Mar 31, 2004 | 12:21 AM
mattEG's Avatar
bump for someone who wants info as well
Old Mar 31, 2004 | 03:41 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (mattEG)
dodge/crysler turbo from mid 80's to early 90's.
.42/.48 a/r ratios and is water/oil cooled. replaced by garrett TB03 of same a/r ratios in 89 with the introduction of the turboII setups.
uses offset T3 inlet which you can get manifold for from here:
http://www.jgstools.com/turbo/index2.html and you use this flange:
Early Chrysler T3 TK100
has a weirdly positioned outlet which can be overcome with use of that manifold as it lets you position the inlet at whatever angle you need so the outlet still points down.
will make great boost up to 18psi on 1.6-2.0L engines and will spool by 3k if not sooner. wastegate is set at 8psi from the factory.
easily clockable as the housings are held on simply by lock rings but you must take off the housings and grind down an alignment pin on each before you can physically clock the housings.
Old Mar 31, 2004 | 04:05 PM
FAST AS's Avatar
Default Re: (stackz)
how much dos it cost to rebuild barings are bad
Old Mar 31, 2004 | 06:05 PM
stackz's Avatar
Community Builder
Default Re: (FAST AS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST AS &raquo;</TD></TR><TR><TD CLASS="quote">how much dos it cost to rebuild barings are bad</TD></TR></TABLE>
hell if I ******* know haha...that's something your local turbo shop will tell you. Or you can "attempt" it yourself by getting a rebuild kit for $75 off eBay from one of the turbo dealers on there and hope you can get it magically balanced without using a balancing machine....
remember, on average at 6000rpm and 8psi of boost...the turbine wheels are spinning at about 50,000rpms...
Old Apr 1, 2004 | 02:03 PM
FAST AS's Avatar
acme turbo in knoxville want 200 dollars for labor and ? for parts does that sound right
RSX2SIcivic
Jun 25, 2009 02:12 PM
tubed-ef
Mar 8, 2007 11:35 AM
spoolingb20
Oct 3, 2006 05:17 AM
JonnyCoupe
Apr 18, 2004 01:53 PM
h22turbolude
Dec 10, 2003 09:30 AM
