please HELP, no VTEC
Old Sep 5, 2002 | 06:48 PM
my91civic's Avatar
Default please HELP, no VTEC
just got my car on the road today for the first time with the turbo, its a t3/to4e, 12:1 FMU, inline pump, stock injectors, oh yeah its on a b16 in a 91 hatch, well after a few trys of not making any boost, i finally got that straight but now i can not figure out why my vtec is not engaging...when it hits 5K rpms it loses power...no vtec, it loses power at 5K and then it starts to make boost after that. and i unpluged vtec and drove it and it doesn't die at 5K it will pull all the way through, so thats why i figure its the vtec not working....so if anyone has any ideas PLEASE let me know....i'm about to go crazy!!!! TIA
Old Sep 5, 2002 | 09:10 PM
Ri5e's Avatar
Default Re: please HELP, no VTEC (my91civic)
hehe....I have no VTEC either
Old Sep 6, 2002 | 08:41 AM
my91civic's Avatar
ANYONE?????
Old Sep 6, 2002 | 09:35 AM
X2BOARD's Avatar
It could be a number of things, really. Need more info.... but....
Did Vtec work b4 the turbo ?
Check you oil level, needs to be full.
Is there a check engine light ? If there is... dump the codes... you may be getting a vtec code.
Low oil pressure can cause no vtec and a CEL, so do you have an oil pressure gauge ?
What is your timing set at ?
Also try running minimum boost, see if she will go into vtec.
I'm sure others will give you ideas...
The setup should rip when it's fixed !
X2
Old Sep 6, 2002 | 09:40 AM
my91civic's Avatar
Default Re: please HELP, no VTEC (X2BOARD)
yeah, vtec worked before turbo, my oil is full, my timing is at 14 degrees, i've only got the boost set 5psi right now, no i don't have any codes. any ideas?
Old Sep 6, 2002 | 09:46 AM
X2BOARD's Avatar
You didn't get a CEL when you unplugged Vtec ?
How are you handling the Map sensor signal w/ the boost ?
[Modified by X2BOARD, 1:47 PM 9/6/2002]
Old Sep 6, 2002 | 09:47 AM
b18bturbo's Avatar
check your vtec solonoid and see if it is working right
Old Sep 6, 2002 | 10:18 AM
DC2R714's Avatar
Default Re: please HELP, no VTEC (b18bturbo)
where is your oil send line routed? Supposedly the send line should be as short a distance from the block to the turbo as possible. Sometimes if the line is too long you will loose oil pressure and vtec will not engauge. Thats why I run my send line over my valve cover. Doesn't look the prettiest but my vtec works.
Old Sep 6, 2002 | 12:38 PM
my91civic's Avatar
i forgot to metion that i have type r cams, could this be my problem? is vtec really working but its too much overlap with the type r cams and thats why i'm losing power at the switchover and my vtec is really working???
Old Sep 6, 2002 | 12:47 PM
niedejb's Avatar
Are you sure the power loss isnt from over fuelling?
I had bogging at 5K rpm up till I got it tuned.
Old Sep 6, 2002 | 02:26 PM
pornstarSR's Avatar
one other thing you can check is where to oil feed is coming from for the turbo, a friend of mine when he first put his turbo kit on tapped into the head for the oil, right next tot he Vtec solonoid
so everytime he got to boosting the turbo stole most of the oil pressure and the vtec would not engage
Old Sep 6, 2002 | 03:48 PM
my91civic's Avatar
Default Re: please HELP, no VTEC (pornstarSR)
mine is teed off the back of the block from the oil sending unit
Old Sep 6, 2002 | 04:31 PM
pornstarSR's Avatar
ok then thats ok.....its seems like a oil pressure problem
Old Sep 6, 2002 | 07:31 PM
my91civic's Avatar
what kind of oil pressure problem could it be then?
1sgranger75
Honda Civic (2001 - 2005)
Sep 27, 2010 08:59 PM
big_turbo_b16
Mar 16, 2007 02:20 PM
breanna*
12
Aug 2, 2006 09:29 AM
CompressionFed
Mar 23, 2004 04:54 AM
gsrhatch530
Mar 28, 2002 01:36 PM
