please help
Old Jan 7, 2004 | 06:09 AM
0 0 0's Avatar
Default please help
i have a turbo'd d16z6 and its been running great for a while now but outta nowhere a couple of nights ago my a/f gauge started reading really lean,i got a #43 code(fuel supply system) but only once but it hasnt came on since...i changed my fuel filter and fuel pump...and its still reading the same...im scared of detonating so im not driving it although it still runs fine....does anyone know why its doing this or what other things i can do to trouble shoot the problem...i was thinking about changing the injectors also,im running stock ones
Old Jan 8, 2004 | 06:01 AM
0 0 0's Avatar
cmon people i need some help here!!!
Old Jan 8, 2004 | 06:05 AM
whiteblurr's Avatar
Default Re: please help (vxHATCHATTACK)
What grade fuel are you using?
What are your FPs?
Are you using a stand alone, Hondata, AEM?........
BROOD's Avatar
How about some more details? type of fuel managment, etc.? Fuel psi?
Did you clear the DTC43 code and it came back?
Old Jan 9, 2004 | 08:52 PM
Inducted's Avatar
im running 40 psi,i am using the missing link,w/a FPR....the check engine light only comes on once in a while not every time i drive it...any suggestions? could it be the o2 sensor,also i read the missing link could also be doin it
Old Jan 9, 2004 | 09:19 PM
Inducted's Avatar
i also run mid-grade fuel and just put octane booster in it to see if that would work but it didnt..any other suggestions????
Old Jan 9, 2004 | 09:22 PM
vaporboy12's Avatar
run as high octan as you can. what octan level do you use?
Old Jan 10, 2004 | 06:59 AM
Inducted's Avatar
Old Jan 10, 2004 | 09:05 AM
Rod.'s Avatar
hatchattack...I had the same problem. I would drive and all of a sudden it will go to red on my af gauge. I pulled the code and it said fuel system blah blah blah. I took my o2 sensor out it was all black. Im guessing it was out for the count. I pulled a o2 sensor from my old dx motor put it in my ls. I never seen that CEL again and it never read lean on my af gauge. Hope it works the same for you
Old Jan 10, 2004 | 09:12 AM
Cyphear's Avatar
If you need to go somewhere you should be alright if you keep the RPMs low and out of the boost. When I was driving untuned my a/f gauge ran dead lean sometimes (sometimes even off the gauge, if u know what i mean). To solve my problem I would just turn the ignition all the way off and on and then back on (while i was rolling or something so I didn't have to restart). Hope this helped in any way.
Old Jan 11, 2004 | 06:46 AM
Inducted's Avatar
i REALLY appreciate all of your help....im gonna see if the o2 sensor is bad...hopefully it is and thats all thats wrong....thanx again
Old Jan 11, 2004 | 11:38 PM
Cyphear's Avatar
No problem. Did you post this originally on a friends account or what? your name changed. Let us know if you find out the problem. o2 sensors are like $60 btw. Usually bad o2 sensors turn on the check engine light. hmm.
NickMorneau
May 30, 2013 05:15 PM
Slain
Apr 18, 2007 12:06 AM
GTEC913
Jun 1, 2005 12:13 AM
IwanAturBo
Mar 16, 2003 06:53 PM
Litoman
Aug 15, 2002 07:53 PM
