piston ring gap
Old Jul 27, 2008 | 02:41 PM
avotegra's Avatar
Default piston ring gap
piston ring gap on a turbo wiseco 81.5mm piston.....looking to get 400 hp.........what is the best gap on the piston ring....
Old Jul 27, 2008 | 07:38 PM
Desir Performance's Avatar
Default Re: piston ring gap (avotegra)
Usually you should have the ring gap specified in the packaging. Usually turbo cars go for .30 on the top ring and .20-.21 on the bottom. (cp pistons)
Old Jul 27, 2008 | 08:30 PM
Turbo B18C EJ6's Avatar
Default Re: piston ring gap (Desir Performance)
What engine is this for? i used .018 top ring and second ring .015 inch for turbo gsr on my build.
Old Jul 28, 2008 | 04:16 AM
blackeg's Avatar
Default Re: piston ring gap (Turbo B18C EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo B18C EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">What engine is this for? i used .018 top ring and second ring .015 inch for turbo gsr on my build.</TD></TR></TABLE>
and i used .022 and .25 for my first and second ring.
theres a formula, its like bore diameter in inches x .0065 or .007
Old Jul 28, 2008 | 10:49 AM
Flamenco-T's Avatar
Default Re: piston ring gap (blackeg)
Wiseco XX use, .016 top and .018 bottom.
XC, may have to increase it by .002-.003
stan
Old Jul 28, 2008 | 10:51 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
theres a formula, its like bore diameter in inches x .0065 or .007</TD></TR></TABLE>
At that rate, your oil will prolly be all over the combustion chamber. Not all rings are made alike, some material hardly expands. I have had Wiseco XX rings on .012 and .013. 2% leakdown and the rings never touched when I pulled it out.
stan
MRturbo
May 19, 2006 07:44 AM
JonGP4
Nov 22, 2003 09:33 AM
sweet
Apr 23, 2003 05:06 PM
Ri5e
Aug 3, 2002 10:51 PM
