Pics of oil return line setups??
Old Jun 3, 2002 | 08:24 PM
HXMan's Avatar
Default Pics of oil return line setups??
Got any? I was going to use 2 45 swivel fittings, a 3/8 to -10an adaptor(Art's list)....it looks like the 45 off the turbo is going to make the line swing down too far, and the line will have to go up to make it to the top of the oil pan.
Anyone else have this problem?
Old Jun 3, 2002 | 10:22 PM
shadowdawn's Avatar
Default Re: Pics of oil return line setups?? (HXMan)
ttt, I would like to see some oil return setup pics also........ leaky rubber hose sucks
Old Jun 3, 2002 | 10:47 PM
Flamenco-T's Avatar
Default Re: Pics of oil return line setups?? (shadowdawn)
try to use a straight AN fitting off of the turbo....
then use the 45 deg to the oil pan
Old Jun 4, 2002 | 06:43 AM
HXMan's Avatar
Default Re: Pics of oil return line setups?? (Flamenco-NA)
I just ordered a 90 deg fitting...so if that doesnt work I will have to buy a straight fitting.
Old Jun 4, 2002 | 07:35 AM
Flamenco-T's Avatar
the 90 Deg that you have, is it the pipe thread to AN union, male to male ?
if that is so, then all you need is to hook up the swivel fitting to it from thr turbo...
I had it like yours before, then I went with straight down ...
see, I use a 90 union, then use the 45 deg fitting, it works, I was leaking a few drops of oil a week...but then I opted for the straight fitting, and never leaked afterwarsd...
Old Jun 4, 2002 | 08:02 AM
CovertFI's Avatar
"FS: JE pistons 9:1 for third gen RX-7, wrists and pins included...$150 shipped..brand new..."
correct me if i am wrong but i thought the rx-7 was rotory. no pistons?
Old Jun 4, 2002 | 08:06 AM
2K_TEG's Avatar
Default Re: Pics of oil return line setups?? (CovertFI)
it's a joke.
Old Jun 4, 2002 | 09:11 AM
93LSivic's Avatar
This is shot from above.
Used the flange adapter to a pipe-an10 fitting. Then a 45--line--45 to bulkhead in the pan.
No drops of oil whatsoever.
jacob4lester
Feb 16, 2010 08:36 PM
Boosted_Coupe
May 20, 2007 12:15 PM
88da3
Feb 1, 2006 03:47 PM
highmilehatch
Sep 28, 2003 07:52 PM
aracer69
Sep 9, 2003 02:04 PM
