PIC REQUEST: Filter placement on a compressor housing on the drivers side
Old Oct 24, 2005 | 12:36 PM
B16Civic93's Avatar
Default PIC REQUEST: Filter placement on a compressor housing on the drivers side
like it says i want some pics of filter placements and types with the compressor housing on the drivers side.
93 coupe, ls/vtec, equal length, sc34
thanks
Old Oct 24, 2005 | 12:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (B16Civic93)
this is my setup. t3-t67 h.o.
K&N part number: ru-2510 it has a 4" inlet though.
Old Oct 24, 2005 | 01:34 PM
m R g S r's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (boostedcivicsir)
Mine is in the same exact place. or was. I hydrolocked my motor the other week with the shitload of rain we got. Be careful...If you can fit an intake pipe you should use one
Old Oct 24, 2005 | 02:07 PM
mrbsponge's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Mine is in the same exact place. or was. I hydrolocked my motor the other week with the shitload of rain we got. Be careful...If you can fit an intake pipe you should use one </TD></TR></TABLE>
man common sense kicked your ***!
with an exposed filter element and obviously we are drawing air above atmospheric pressure, we should all know that this isnt something that should be just driven around town. you can put a pipe on there, i fitted mine with my old drag intake pipe just cut a few inches off, when i go to the track i just take it off
Old Oct 24, 2005 | 08:46 PM
DaveF's Avatar
https://honda-tech.com/gara...=1249
Old Oct 24, 2005 | 09:08 PM
2k.civic.si's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/gara...=1249</TD></TR></TABLE>
thats pretty cool
Old Oct 24, 2005 | 09:19 PM
AbitAvenger's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (2k.civic.si)
^^^nice diy
Old Oct 25, 2005 | 03:29 AM
BoostedCivicSedan's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (AbitAvenger)
OK, Couple questions...
How safe is it to cut through the frame rail like that?
Will it pass tech at an NHRA/NDRA even?
Do you put a filter on there and the splash guards to cover it?
What did you use to cut the frame rail?
Was it honestly worth the work, and do you have anything to back it up if you say yes?
Not tryin to give you a hard time... Just looks kinda nifty and I wondered if it would be worth doing something like that
Old Oct 25, 2005 | 04:01 AM
m R g S r's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (BoostedCivicSedan)
I don't think it's his car.....
Old Oct 25, 2005 | 04:10 AM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivicSedan &raquo;</TD></TR><TR><TD CLASS="quote">
Not tryin to give you a hard time... Just looks kinda nifty and I wondered if it would be worth doing something like that</TD></TR></TABLE>
i think i would drown the motor on my burnout, much less soak the filter as well, if it were open like my fenders are
Old Oct 25, 2005 | 05:17 AM
DaveF's Avatar
1. safe, why wouldnt it be? we are talking about tin cans here.
2. sure why not?
3. yes, it has a small bend coming off the frame rail with the original fender liner.
4. a 3inch hole saw, will cut through no problem, then just weld another section of tube into the framerail to make it complete.
5. yea, it was worth the work. one of the previous filters had gotten so heated that the glue came apart from the filter and the base. (filter fell off) with the filter like this, you are not sucking all the hot engine bay air, and there is alot less of a chance your filter will fall apart due to heat.(it was previously clamped directly to the compressor housing.
Old Oct 25, 2005 | 11:44 AM
Mr. Badwrench
i appreciate the thoughts, but it is a fair weather car, it only sees rain when the occasional storm pops up. it isnt my daily.
Old Oct 25, 2005 | 05:21 PM
80884's Avatar
Default Re: PIC REQUEST: Filter placement on a compressor housing on the drivers side (rota92)
What are these filter things you guys keep talking about?
I wish I would have put more thought into filter location when i built my manifold. Now if I want to run a filter I pretty much have two options....modify car to alow a 4" pipe to connect to turbo and out of engine bay and then put filter there or...Fabricate aluminum sheetmetal airbox underhood that connects to turbo and run pipe off of that box outside to get some air in. One good thing...it's lined up nicely with the headlight for my other (track only) air induction setup
EDIT: Don't say get rid of the powersteering stuff. The powersteering is still hooked up with some modification and will be fully functional with the top mount turbo manifold and 4" dp (soon to be made).
Hoosier Daddy
Nov 2, 2010 08:53 AM
eg crunkmonster
May 8, 2006 09:06 AM
coupon
Aug 13, 2005 12:16 PM
ScottEK
Jul 16, 2003 01:14 PM
