the phantom boost leak
Old Nov 3, 2002 | 12:07 AM
  #26
turbopanda's Avatar
Default Re: the phantom boost leak (Etylorcen)
maybe your turbo is broken
Old Nov 3, 2002 | 12:09 AM
  #27
Armed Ferret's Avatar
a thought if you haven't tried it already:
get some soapy water. put it (carefully, obivously) in different places along your charge pipes. bubbles = leak.
Old Nov 3, 2002 | 06:35 AM
  #28
SiR Kid's Avatar
New User
Default Re: the phantom boost leak (zoomintegra)
Soapy water that's like half water/half dishwashing detergent...
If it's making a farting sound, it sounds like one of the eurethane pipe connectors is leaking...
The idea of the friend gassing it while you listen sounds good to me. Just do it like Gran Turismo, mat the gas to get it spooling, then let off, and just mat and let off repeatedly, not letting the engine actually rev over 4-5k rpm, so you don't spin a bearing or anything stoopid. You should hear it with the turbo spooling a good bit at WOT while doing this, just like it was a really crappy two step
Just my $.02, hope it helps.
Old Nov 3, 2002 | 06:45 AM
  #29
falcongsr's Avatar
What is this crap?
Default Re: the phantom boost leak (SiR Kid)
i cant move enough air in neutral to boost or spool the turbo at all.
fuel rail is snug
but i can bring it down some more
and not snap off the studs hopefully
Old Nov 3, 2002 | 06:55 AM
  #30
SiR Kid's Avatar
New User
Default Re: the phantom boost leak (falconGSR)
I can spool my 4/3 on my li'l b16a to 5 psi in neutral, I'm sure the little GReddy will TRY to make full boost by doing this, trust me.
Old Nov 3, 2002 | 07:10 AM
  #31
falcongsr's Avatar
What is this crap?
apparently, something is seriously wrong then.
Civic Racer X 7
May 29, 2007 01:57 AM
rusteds2k
Jan 7, 2004 09:33 AM
zojirushi
Aug 8, 2002 09:55 AM
DIRep972
Dec 4, 2001 05:11 AM
greyzone
Oct 20, 2001 11:17 AM
