People with greddy or other "kits" on a 99-00 civic ex read. need help
Ok on your kit, where does the 2 hoses and the AIR TEMPERATURE sensor go?
Does the valve cover hose and the other hose go before the turbo or it's on the same pipe near the TB? Same goes for the IAT sensor.???
Re: People with greddy or other "kits" on a 99-00 civic ex read. need help (2000vsm)
iat goes in the charge pipe just before the throttle body like on a n/a air intake...just use a rubber grommet. use breather filter on the valve cover or run a hose from the valve cover to the fresh air intake tube between your filter and turbo.
Re: People with greddy or other "kits" on a 99-00 civic ex read. need help (scttydb411)
won't the higher air temp from the compressed air affect fuel delivery?? i heard people putting the iat between turbo/filter
also what about the 3rd hose... ok lemme take a pic of my car and show you what i mean the 3rd hose
I ran my IAT in my charge piping just before the TB, like stock. Worked with no problems.
you want to keep it in the charge pipe before the turbo because that is the air that the engine is using to mix with fuel. the temp of that air will determine timing and a/f ratio. putting it all the way before the turbo between it and the air filter will mean it will be reading the air before it is compressed/heated/cooled through fmic etc. it just won't be the right way to do it.
definately show the pics of the hoses you speak of.
Re: (scttydb411)
Ok so you sure IAT goes in stock location eh? How can i make sure no leaks and stuff, it comes out easily to me..
ok here is pics, if pics don't work, click on this link after pics
http://forums.clubsi.com/showf...t=&vc=
crazyguy
04-13-2008 09:45 PM
