Pefect Place for Fuel Vent when removing your EVAP Carcoal Canister...
When you remove the carcoal canister from most civics and integras there is a plastic piece that runs out the bottom the the canister. When you remove the carcoal canister also the fuel vent off of the fuel tank is usually left open behind the motor and releases fuel vapors into your engine bay, which I am certain isnt very good. I used a piece of 5/8 heater hose and ran hose clamps to connect the fuel vent line that is in the middle of the firewall to the plastic connector that is at the bottom of the passanger side of the firewall so the vapors no just go out the bottom of the car. Problem solved.
1 Post
Re: Pefect Place for Fuel Vent when removing your EVAP Carcoal Canister... (400WHPITR)
isnt the fuel vent line a little 1/4 inch hose? i think it is on my civic...i guess i could be mistaken though
Re: Pefect Place for Fuel Vent when removing your EVAP Carcoal Canister... (Tinker219)
The fuel vent line on my integra was just under an inch and was right in the middle of the brake lines on the firewall.
1 Post
i should go look at my car...i havent really looked closely at it since november...i kidna miss it. its still half-burried in snow...
for about 5 bucks and 10 min should be better than having those fuel vapors possibly catch your car on fire...
rice_classic
21
04-10-2013 09:59 PM
