REAL fuel line tech.. Pt#s...
Ok, i have been recently looking for the part numbers to make a fuel line. I didnt want to purchase one for 90 bucks so i made my own....
here is the info.
http://www.anplumbing.com
1)pt# 991945 carburetor adapter solex dellorto, mikuni 12mm x 1.25 to -6an $5.66x2.
2)pt#815006 swivel seal 150deg tube hose end $20.01 x 2
3)Stainless Steal hose pt# 3000006 $5.45 per foot.
How to.
take fuel rail and with a stud remover socket remove the fuel rail stud. Screw in #1. Remove fuel line from fuel filter, screw in the other #1. Assemble the new fuel line like this. http://www.diyracing.com/sshowto.html. The rest is self explanatory, just hook up the line and your done.. Brand new Ss line you made yourself and saved 30-40 dollars.. You can find SS line cheaper on different websites, i just used AN plumbing as a reference....
HTH... PM for questions... Oh, you can also do oil lines just as simple...
Later
here is the info.
How to.
Later
Re: REAL fuel line tech.. Pt#s... (Lyrikz)
Thanks for the write up. I'm going to be doing this very soon on my car as well. I hear some people using a 180 degere instead of the 150 degree fitting you use. I guess it makes no big of a difference.
How many feet of SS line did you end up using?
Danny
Danny
Re: REAL fuel line tech.. Pt#s... (R6Elmo)
well, you dont want it goijg STRAIGHT down cause stuff gets in the way.. your alot safer if you use the 150 degree.. but hey, give it a try.
My car is eg with h22 in it... I put the accord fuel rail on and the Stock fuel line was just a TINY bit short.. It worke,d but it was stretching... Thats why i put the ss line on... Plus i love makin that ****. ahaha..
Yup. I have a b18b in my eg, and my fuel line looks a bit short too. I'll go home and measure to see how much fuel line i need. I normally order from summitracing.
Sumimt is a bit much.... Also, you have to order by the foot.. so just order 2 feet and then go from there... It took me 4 minutes to make the SS line... Another 4-5 to install it.... Looks nice to.
D
D
summit racing is actually the same price as many. Also why did you use 2 150 degree ends? one 150 degree end goes from the fuel filter, and you should have a straight end going to the fuel line right?
ya, you can have a straight end hooked up to the 12mmx1.25 or you can have a 150degree one.. i did the 150degree one because i didnt want the fuel line sticking up out of the fuel rail.
Ill post some pics tomorrow.
Sweet. I'm not totally picturing it i guess. IM me when you get the pics up. I'll probally order from summit tomorrow or something.
Luke G.
14
09-10-2009 06:07 PM
h22acivichybrid
06-14-2004 03:20 PM
