PCV VALVE HOSE
Old May 22, 2014 | 08:49 PM
JHipps's Avatar
Default PCV VALVE HOSE
Where does the other end of the hose run to? My intake mani? Or somewhere else?
Old May 22, 2014 | 10:33 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: PCV VALVE HOSE
What motor.
and you can't use the pcv system on a boosted motor. all pcv valves leak and if you run the hose to your intake manifold you'll be pressurizing the crankcase which is a bad thing any way you look at it.
The pcv system relies on vacuum to eliminate blowby vapors and lower crankcase pressure, increasing the crankcase pressure causes all sorts of issues. this is why you see people running atmospherically venting catch cans
Old May 22, 2014 | 10:57 PM
JHipps's Avatar
Its an LSV. B18A1 Block. B16 Head
So should i just let it hang there or?
Old May 23, 2014 | 03:28 AM
LTCxD2B's Avatar
It's supposed to go to the breather box on the back of the block if U don't have one then it will just hang there since the b16 doesn't have the PVC hole in the valve cover like the LS
Old May 23, 2014 | 07:36 AM
90blackcrx's Avatar
Install a catch can system, don't hook it up like a stock setup or bad things will happen....
Old May 23, 2014 | 10:43 AM
JHipps's Avatar
so what can i do for the time being until i install a catch can?
Old May 23, 2014 | 02:22 PM
LTCxD2B's Avatar
If ur turboed then u can just plug the hole in the manifold and run the out let of the PVC to open air or preturbo in the inlet pipe
Old May 23, 2014 | 03:35 PM
TheShodan's Avatar
Moderator
ohh boy..
Old May 23, 2014 | 03:37 PM
JHipps's Avatar
Originally Posted by TheShodan
ohh boy..
s10cky
Nov 20, 2006 12:24 AM
type B16
Sep 24, 2006 04:14 PM
gsr dood
Mar 20, 2006 07:24 PM
riceball777
Feb 6, 2006 07:15 AM
JerseySiPOS
12
May 16, 2004 10:40 AM
