PCV valve on B16 Turbo setup.
I recently accidentally snapped my PCV valve in half. I was told that I don''t need to run one. right now I have the manifold end blocked off and the other end open.
do i need to reconnect it?? or is it OK to leave it off.
Re: PCV valve on B16 Turbo setup. (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">That's fine!</TD></TR></TABLE>
also smoke is now coming out of where the breather is.
which is why I asked. because I thought the whole purpose of it was to re-circulate blow by gases.
It has been fine like this for a long time. so does this mean I have serious engine problems???
search for the oh expletive i'll do it myself:
first read this one: https://honda-tech.com/zerothread?id=697498
then this one: https://honda-tech.com/zerothread?id=1199935
Re: PCV valve on B16 Turbo setup. (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">search for the oh expletive i'll do it myself:
then this one: https://honda-tech.com/zerothread?id=1199935</TD></TR></TABLE>
thanks great info.
this should solve the problem
thanks great info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">if you figure it takes 10-15min for a response or two, everything has been covered before. 10-15min of searching usually nets some posotive results </TD></TR></TABLE>
last 3 months of trying to use the search, so don't assume everyone has access to it:
2stroke1971
06-26-2019 06:33 AM
moesrex
05-23-2006 08:55 AM
