overheating ?s
Old Oct 15, 2010 | 06:28 PM
slowboy90's Avatar
Default overheating ?s
so heres the setup
85mm ls vtec
wiseco pistons
crower rods
acl race bearings
cometic head gasket
ported head
stock dual core civic si radiator
slim fan pushing air
s366 topmounted on sls twin gated top mount manifold
turbo blanket
heat wrapped down pipe
the car only seems to over heat after a pretty hard street run but once its hot it seems to stay there or drop some then go back up.
any advice is greatly appreciated!
Old Oct 16, 2010 | 09:16 AM
dpetro1's Avatar
Default Re: overheating ?s
i think pretty much all turbo hondas suffer from lack off airflow due to the fmic blocking the grill. so you either need to get fresh air to the rad or just a better fan setup w/ shroud. no name slim fans dont flow as much as they claim. also, using a puller is more effective.
Old Oct 16, 2010 | 10:31 AM
jetspeedz's Avatar
get a good shroud as mentioned and if its the stock si radiator i would ditch it and go with aftermarket like pwr or koyo
Old Oct 16, 2010 | 12:34 PM
EsotericImage's Avatar
Retired Moderator
Mishimoto triple core and a good fan like Xenocron.com sells.
Thos crappy slim fans are garbage. That maradyne 13" should be the last fan you will ever need.
Old Oct 17, 2010 | 07:55 PM
M-Town EG's Avatar
i had the same problem with my gsr-t untill i took the radiator out and got it cleaned. since my radiator is oem and 15yrs old it build up deposits. thats my .02 cents
Old Oct 18, 2010 | 04:46 AM
slowboy90's Avatar
thanks for the help guys i guess its time to upgrade it i just recently changed up the manifold setup and i figure it placed it closer to the radiator or something but time for a koyo or maybe a fluidyne and a good fan
Old Nov 11, 2010 | 07:01 PM
slowboy90's Avatar
well i had my stock cleaned so i can try to make an event sunday and the lower radiator hose is staying cold so i changed thermostats still does it so i think maybe air bubble as well
BIG LUIS
Jul 31, 2014 07:49 PM
balbowskie
Feb 27, 2013 02:16 PM
g2turbo
Oct 16, 2009 07:36 PM
schock3
Aug 10, 2009 10:30 AM
ScottEK
Jul 30, 2003 05:05 AM
