Overheating problems
Old Jul 2, 2002 | 12:46 PM
khang77642's Avatar
Default Overheating problems
here's my setup:
Greddy turbo kit for sohc
450 cc DSm
255 walbro fuel pump
VAFC
msd 6a
b&m fuel regulator
2 1/2 exhaust
ngk plugs gap at .032
del sol vtec radiator
Everytime i run the car hard a few times... my car starts to overheat.... but drops If I start driving normal. I am boosting 10lbs. My autometer a/f gauges says I'm running rich and one or two yellow box in stoich. Am i running lean? I am currently using the VAFC hack. I do not hear any detonation. Anyone of yall guys got any suggestion ? Thanks in advance
Old Jul 2, 2002 | 12:47 PM
CovertFI's Avatar
Default Re: Overheating problems (khang77642)
how does your fluid look?
Old Jul 2, 2002 | 01:02 PM
khang77642's Avatar
Default Re: Overheating problems (CovertFI)
have not check it yet ? I just recently change my headgasket not too long ago. what should i look for ?
**only overheat when I driving hard and slightly goes up when I pass a car on the highway, but drop instantly after I am crusing at mild speeds
[Modified by khang77642, 4:04 PM 7/2/2002]
[Modified by khang77642, 4:05 PM 7/2/2002]
Old Jul 2, 2002 | 01:05 PM
Sonny's Avatar
Are you sure you don't have air trapped in your cooling system?
Sonny
Old Jul 2, 2002 | 01:10 PM
khang77642's Avatar
Default Re: Overheating problems (Sonny)
I'm not sure about that, but that is a good idea,could that be the reason why my car is behaving like that? because when I put the headback together and installed a new thermostat. Filled the motor with fluid, but never pump the air out..I remember my brother did it for me the first time before I blew the headgasket, but not after. I am going to try that, but is there any other suggestion too ? Thanks
Old Jul 2, 2002 | 01:29 PM
TurBoXBirD16's Avatar
that sounds like it's air in the coolin system
coz if u just feel it, and didn't blee it, 100% air then
quik sol
Aug 24, 2004 05:22 PM
aemciv
Oct 2, 2003 02:58 PM
turbocivic22
Mar 2, 2003 09:25 AM
BDTURBO
Feb 27, 2003 10:56 AM
VTC_CiViC
Sep 17, 2001 11:31 AM
