is overheating normal after installing turbo?
Old Oct 14, 2004 | 09:09 PM
  #26
kun3racer's Avatar
Default Re: (kun3racer)
well i changed the water pump, timing belt, put a new thermostat in, flushed the motor and radiator, put in new coolant, and bled the system and still not any better...does anyone suspect a clogged radiator? i shot water through it with a water hose and water was flowing out the other end but maybe it wasnt flowing like it should...also ive ran this radiator for a while with no problems so i dont think that its to small one for my motor. whats next on the check list?
Old Oct 14, 2004 | 09:22 PM
  #27
VinceVTEC's Avatar
my car also overheated after the turbo install. My thermoswitch went faulty for some reason, after i changed it. everything was fixed.
Old Oct 14, 2004 | 09:58 PM
  #28
d15b7racer's Avatar
Default Re: (VinceVTEC)
just change the radiator already.....u live in hawaii bro....especially if you're from waianae....its hot. ever since i turboed my car my car runs a little hotter than it used to with my stock radiator
Old Oct 14, 2004 | 10:59 PM
  #29
kun3racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VinceVTEC &raquo;</TD></TR><TR><TD CLASS="quote">my car also overheated after the turbo install. My thermoswitch went faulty for some reason, after i changed it. everything was fixed.</TD></TR></TABLE>
so was your thermo switch not turning your fan on at all or was it turning it on but not soon enough? cuz my fan turns on but maybe its not turning on soon enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b7racer &raquo;</TD></TR><TR><TD CLASS="quote">just change the radiator already.....u live in hawaii bro....especially if you're from waianae....its hot. ever since i turboed my car my car runs a little hotter than it used to with my stock radiator</TD></TR></TABLE>
yeah thats next on the list but i think ill try a new thermoswitch first since its alot cheaper.
Old Oct 14, 2004 | 11:05 PM
  #30
donkiman's Avatar
Default Re: is overheating normal after installing turbo? (kun3racer)
mine was overheating after my install. i replaced thermostat and then all worked well.
Old Oct 14, 2004 | 11:24 PM
  #31
d15b7racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kun3racer &raquo;</TD></TR><TR><TD CLASS="quote">
yeah thats next on the list but i think ill try a new thermoswitch first since its alot cheaper.</TD></TR></TABLE>
yeah radiators are pretty bank especially since its hard to find things locally got pay out the **** for shipping. i wanna get a new rad. too. if you find a good one locally let me know where dude!
Old Oct 15, 2004 | 06:51 AM
  #32
VinceVTEC's Avatar
Default Re: (d15b7racer)
definitely try the thermostat!!! because i thought it wasn't my thermostat at first because my fan was still turning on, but i guess it was being screwy, it wouldn't turn on at the right times? Anyways, after replacing the waterpump, thermostat, c&r radiator... i thought i would give a last try and put in a new thermoswitch and voila! So my lesson learned was start w/ the cheapest items first!
Old Oct 15, 2004 | 07:33 AM
  #33
jlperformance's Avatar
Mine done that on a gsr turbo. Turns out it was the radiator, the stock single core radiator just dont cut it. Get one from a automatic car or a dohc vtec civic or del sol. Found mine at autozone for 99.00. Just my 2cents.
Old Oct 15, 2004 | 10:53 AM
  #34
kun3racer's Avatar
Default Re: is overheating normal after installing turbo? (jlperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlperformance &raquo;</TD></TR><TR><TD CLASS="quote">Mine done that on a gsr turbo. Turns out it was the radiator, the stock single core radiator just dont cut it. Get one from a automatic car or a dohc vtec civic or del sol. Found mine at autozone for 99.00. Just my 2cents. </TD></TR></TABLE>
did you have one of those skinny radiators with the plastic end tanks? the one i got is the more thicker one with metal end tanks. i think its dual core .
Old Oct 16, 2004 | 01:08 AM
  #35
kun3racer's Avatar
okay i changed the thermoswitch and it got a lil better. well i drove it at night so im gonna see how it does in the hot hawaiian sun tomorrow. hopefully its my radiator and not my head gasket. maybe it was my thermoswitch along with something else. anyways only one more thing left before i change the head gasket.
Old Oct 17, 2004 | 02:52 PM
  #36
kun3racer's Avatar
does anyone think that my slim fan is not strong enough? should i go back to stock?
Old Oct 17, 2004 | 03:25 PM
  #37
kulangot's Avatar
my friend had that slim fan and he went back to a stock fan, and he looped the relay so its always on, no more overheating.
Old Oct 17, 2004 | 05:46 PM
  #38
92SleepyHB's Avatar
Default Re: is overheating normal after installing turbo? (sirq2u)
Your thermoswitch is probably gettin stuck, but i would recommed an aftermarket radiator
Old Oct 18, 2004 | 11:47 AM
  #39
kun3racer's Avatar
Default Re: is overheating normal after installing turbo? (92SleepyHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SleepyHB &raquo;</TD></TR><TR><TD CLASS="quote">Your thermoswitch is probably gettin stuck, but i would recommed an aftermarket radiator</TD></TR></TABLE>
well its a brand new thermoswitch and alot of people are running on stock radiators with no problems.
Old Oct 18, 2004 | 11:50 AM
  #40
kun3racer's Avatar
last night i drove it to my friends house which is about 45/50 miles away. it overheated when i was heading there (day time) but when i was heading home (at night) it didnt.
Old Oct 18, 2004 | 07:18 PM
  #41
d15b7racer's Avatar
think your radiator just cannot handle.
Old Oct 18, 2004 | 07:23 PM
  #42
Blkteg97's Avatar
Default Re: is overheating normal after installing turbo? (d15b7racer)
You probably should look into an new radiator.
Old Oct 21, 2004 | 01:48 PM
  #43
kun3racer's Avatar
Default Re: is overheating normal after installing turbo? (Blkteg97)
it was the radiator guys! the car is fine now. i bought a dual core delso radiator...hope this helps someone else in the future!
chrisfromsrq
Oct 14, 2009 11:52 AM
j.dizzle
May 20, 2007 10:32 AM
Wo-Nelly
Apr 4, 2004 08:33 PM
teq1816
Jun 30, 2001 06:55 PM
