questions about block girdle
Old Oct 19, 2004 | 11:28 AM
BoostedsiR's Avatar
Default questions about block girdle
block girdle are these nessasary on a built motor. I have a built sleeved 2.0 liter ls vtec, I was just wondering if I should throw one on or can I go with out it. Does the girdle make my motor more safe?
any info would be appreciated
Old Oct 19, 2004 | 11:44 AM
underpressure02's Avatar
Default Re: questions about block girdle (BoostedsiR)
I would also like to know.
Old Oct 19, 2004 | 01:09 PM
BIG RICH's Avatar
Default Re: questions about block girdle (underpressure02)
then that makes three. I am right in the middle of my motor build and I'd like to know its benefits, if any.
Old Oct 19, 2004 | 01:13 PM
93LSivic's Avatar
The girdle will aid in strengthening the mains by tying them together. If you have a sleeved block then the mains already lost some of their rigidity.
Yes, a girdle will help your motor last longer and keep the crank/oil pump happy.
As with everything else, there is a right way and a wrong way to have the girdle installed.
Here is a great example of an excellent girdle. With this one you can use a stock oil pan....others you may not be able to. I am a dealer for these, contact me if your interested.
Old Oct 19, 2004 | 03:53 PM
BoostedsiR's Avatar
Default Re: questions about block girdle (93LSivic)
who is that made by ?
Old Oct 19, 2004 | 04:16 PM
manekDC2.'s Avatar
Endyn makes a very solid girtle
Old Oct 19, 2004 | 05:01 PM
BoostedEG6's Avatar
Default Re: questions about block girdle (manikgsr)
the one thing you have to make sure of when using the after market girdles is that you have a machine shop put it in due to the clearences will throw off the main caps and then you have crank walk... but I would just not use it and keep it off since it didnt come with one and just not rev it past 8500 and you will be safe
Old Oct 19, 2004 | 10:21 PM
93LSivic's Avatar
Default Re: questions about block girdle (BoostedEG6)
Actually crank walk is something totally different. That is when there is excessive movement with the crank from being pushed back and forth with the clutch....or movement from the #1 to #5 mains. This is where the thrust bearings come into play.
Old Oct 20, 2004 | 05:07 AM
BoostedsiR's Avatar
yeah I wont take it past 8
Old Oct 20, 2004 | 10:23 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">yeah I wont take it past 8</TD></TR></TABLE>
If your not going to take it past 8 then I wouldnt even worrie about putting one in. I mean yeah I would if you where going to have a machine shop do it so all the clearences are right then you could go up to 9. but its your motor and your the one building it so its really up to you. good luck hope everything works out for you
Old Oct 20, 2004 | 11:23 AM
Darton Sleeves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Actually crank walk is something totally different. That is when there is excessive movement with the crank from being pushed back and forth with the clutch....or movement from the #1 to #5 mains. This is where the thrust bearings come into play. </TD></TR></TABLE>
93LSivic....he's good....
Old Oct 20, 2004 | 12:28 PM
93LSivic's Avatar
Default Re: questions about block girdle (Darton Sleeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">who is that made by ?</TD></TR></TABLE>
This beutiful piece is made by ERL Performance. These are good in stock, but in limited quantities.
PM me, or call for pricing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">
93LSivic....he's good.... </TD></TR></TABLE>
Thanks Just trying to help out and spread knowledge.
Old Oct 20, 2004 | 12:34 PM
BoostedsiR's Avatar
I appreciatte all the info thanks
Old Oct 20, 2004 | 05:20 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
If your not going to take it past 8 then I wouldnt even worrie about putting one in. I mean yeah I would if you where going to have a machine shop do it so all the clearences are right then you could go up to 9. but its your motor and your the one building it so its really up to you. good luck hope everything works out for you</TD></TR></TABLE>
good point, has anyone had a problem due to having an aftermarket girdle?
Old Oct 21, 2004 | 01:16 PM
93LSivic's Avatar
Default Re: questions about block girdle (Mad Chemist)
Here is a good thread I made about girdles.
https://honda-tech.com/zerothread?id=1030944
Old Oct 21, 2004 | 01:55 PM
FredoSP's Avatar
I would def get one b.c of the length of stroke. If it was a B16 then I wouldn't do it, but it wouldn't hurt.
Endyn makes a nice one also.
http://www.theoldone.com/components/block_girdle/
Old Oct 21, 2004 | 02:08 PM
93LSivic's Avatar
Default Re: questions about block girdle (FredoSP)
Why bother tying 3 mains together? Might as well just get a stock GSR girdle for all that. If your gonna do it, do it right the first time and get all 5 tied up. Not saying Endyn's is bad......there price is less expensive though, but you get what you pay for I suppose.
b18bc3po
17
Oct 8, 2009 07:28 AM
96leatherhatch
Dec 26, 2008 04:32 PM
beater1
Aug 1, 2008 05:15 AM
highbrid
Oct 14, 2002 08:33 AM
