overheat, radiator cap???
Old Jun 29, 2003 | 07:26 PM
88crxvtec's Avatar
Default overheat, radiator cap???
just put a t3/t4 on my CRX. Using a VW radiator my ? is that I can drive it around for a while and the temp will stay about 1/4 or a little higher, then after about 10-15 min of driving it creeps up. I am using a filler neck with a mustang radiator cap that says 13lbs which I guess is around .8 or .9 bar. Stock honda is 1.1 so I'm thinking that may be the problem. I'm only running .45bar of boost, no coolant loss and running a fan all the time.
HELP I have to drive 451 miles in 2 weeks!!!!!
Old Jun 29, 2003 | 07:31 PM
Pelican's Avatar
Default Re: overheat, radiator cap??? (88crxvtec)
how big is the VW radiator. Like full sized or half sized? And thin, med or thick.
You're probably making more HP and therefore more heat. Might need to adopt a bigger/better radiator
Old Jun 29, 2003 | 07:35 PM
88crxvtec's Avatar
Default Re: overheat, radiator cap??? (Pelican)
full with and a little smaller top to bottom. Full aluminum
Old Jun 30, 2003 | 05:25 AM
88crxvtec's Avatar
bump for the morning crowd
Old Jun 30, 2003 | 05:57 AM
Erik B's Avatar
well I have the spoon radiator cap and it started over heating on me. I put the stock cap back on and it didn't do it anymore. I've heard the spring goes bad in the cap causing this to happen. I had the cap on there for about 2 years before it went bad on me......
Old Jun 30, 2003 | 06:05 AM
MiraiZ's Avatar
Default Re: (Erik B)
other than keep the pressure in...how would a radiator cap keep temps down?
Old Jun 30, 2003 | 01:59 PM
Pelican's Avatar
Default Re: (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">other than keep the pressure in...how would a radiator cap keep temps down?</TD></TR></TABLE>
yeah, the cap isn't the problem if the temp gauge says the water's too hot. Are you sure there's no air bubbles in the system. Burp the whole thing to make sure. and what % water/coolant.
Just some things to consider
Old Jun 30, 2003 | 02:08 PM
MayhemSi's Avatar
Be sure to check the resevoir for black particles to make sure your head gasket isn't leaking from either being blown or the head lifting under boost. I definitely agree to try to burp the system first to get all the air out. Another option is to get a bigger radiator. I personally run a Fluidyne with the stock fan and have had not a single problem with overheating since I put it on. There are definitely several different things that could cause overheating.
Old Jul 1, 2003 | 12:09 PM
88crxvtec's Avatar
Default Re: overheat, radiator cap??? (MayhemSi)
I think I figured it out, I had my fan blowing on the motor which blew hot air on the radiator, I reversed it and sucked air through it and it seems to be working, still gonna burp the system too.
Old Jul 13, 2003 | 03:31 PM
B_1_8_hatch's Avatar
how do you burp the system? i have an integra ls motor and i don' t see a deal to burp the system with.
Old Jul 13, 2003 | 04:35 PM
MiraiZ's Avatar
Default Re: overheat, radiator cap??? (93hb)
take off radiator cap while engine is still cold.
start engine
let it idle until the fan comes on
if you have air bubbles in the system, you should see the coolant bubble up a bit and the level go down...
refill coolant if necessary
Old Jul 13, 2003 | 04:43 PM
Default Re: overheat, radiator cap??? (MiraiZ)
so if there is air in there the coolant will bubble up?
when the bubbles stop, that means the air is out?
Old Jun 7, 2006 | 10:22 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: overheat, radiator cap??? (B_1_8_hatch)
bump, my eg 1/2 size rad is making me run at like 230*
Ive got a slim fan that pushes that air out towards the front of the car
No idea why im overheating
Old Jun 7, 2006 | 04:29 PM
nsxmatt's Avatar
Default Re: overheat, radiator cap??? (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">bump, my eg 1/2 size rad is making me run at like 230*
No idea why im overheating</TD></TR></TABLE>
Way to go, 3 year old thread
The fan pushes the other way with the air going towards the motor.
Old Jun 7, 2006 | 05:11 PM
Dunc's Avatar
BCICAN
Perhaps you are overheating because your fans are going the wrong way Reverse it because fans need to be blowing toward the engine.
Old Jun 7, 2006 | 05:31 PM
RCautoworks's Avatar
Pressure raises boiling points, so if the cap is not keeping pressure the boiling point can be coming down causing the car to run hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_1_8_hatch &raquo;</TD></TR><TR><TD CLASS="quote">so if there is air in there the coolant will bubble up?
when the bubbles stop, that means the air is out?</TD></TR></TABLE>
Yep
driveslow
Mar 8, 2009 12:22 PM
jose310
Jul 6, 2008 12:05 PM
gutted-dx
13
Nov 10, 2005 09:11 AM
