Overboosting ...
Old Jul 1, 2001 | 12:41 PM
LsTurbo91's Avatar
Default Overboosting ...
I recently installed a filter with a 45 degree bend on my turbo. I've always had a mesh on there and thought it was time to put a filter on it. Well everything went smooth except now im overboosting. I haven't taken it out yet to find out if its causing it or not. But the filter itself is a ram air type where its getting cold air. Could a ram air effect cause my overboosting problem?
Old Jul 1, 2001 | 02:33 PM
Drag3GSR's Avatar
New User
Default Re: Overboosting ... (9psiLsT)
a ram air effect will not cause an overboost problem... you couldnt possibly ram more air in there than the turbo sucks in... otherwise we wouldnt need a turbo, and intake would add 100hp!!... on a more serious note the overboost problem is more likely due to a leak in the wastegate signal line... I have to change mine about once every month or 2... it gets really hot and eventually fails... I can rarely see any leaks, but I overboost, then I change that line and it is fine... try that!
Old Jul 1, 2001 | 02:52 PM
LsTurbo91's Avatar
Default Re: Overboosting ... (Drag3GSR)
I tried that, I even bypassed my profec B and put a new line from the compressor to the side port.... I will recheck it again though. Thanks
foxdie
Dec 7, 2012 04:21 PM
dannydos
Jun 26, 2005 06:50 AM
alias 33
22
Jan 18, 2004 07:22 PM
igo4bmx
Aug 1, 2003 06:30 AM
Mr.DC2TurBo
Feb 4, 2003 06:41 PM
