which filter/intake mod?
I want to put a new air filter on my car but don't know which one will give e etter performance. My choices are-
my stock air box and snorkel with a k&n air filter
a cone filter(non cold air)
a sponge style filter (non cold air)
stock air box with k&n and gutt it out
If I use the non cold air filter will performane cancel itself out by the filter taking in hot engine air?
Re: which filter/intake mod? (b18c5_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c5_motor »</TD></TR><TR><TD CLASS="quote">you should get a cold air intake if the car is turbocharged.</TD></TR></TABLE>
You should read and learn. If you have a cold air intake, it doesn't make a ****. For one, yoiu have to replace your intake or chop it up to use it with a turbocharger, and 2, when it goes through the turbo the air gets heated anyway.
As far as the original question, I would say get a short ram, route it into the stock airbox, and stick a K&N in it.
1 Post
Re: which filter/intake mod? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
You should read and learn. If you have a cold air intake, it doesn't make a ****. For one, yoiu have to replace your intake or chop it up to use it with a turbocharger, and 2, when it goes through the turbo the air gets heated anyway.</TD></TR></TABLE>
bwahaha owned
bwahaha owned
1 Post
Re: which filter/intake mod? (alias 33)
i'd throw a K&N filter in the stock boxand take out the resonator box hidden in the fenderwell.you could even run a small length of pipe or hose from the bottom of the airbox through the hole in the fenderwell where the resonator used to pass through.this will feed the filter cool air,and won't cost you much money.you could also get a cheap CAI off Ebay for probably the same price.
chris
chris
w3rd
w3rd
Re: how bout' this one? (alias 33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alias 33 »</TD></TR><TR><TD CLASS="quote">will this work well?
http://cgi.ebay.com/ebaymotors...33621
or should I get this one? does the filter design matter much?
http://cgi.ebay.com/ebaymotors...33659</TD></TR></TABLE>
No, those are cheapo paper filters. Get a K&N that will drop into your stock airbox. The K&N filters are reusable, and have a million mile warranty. 40 dollars up front might seem high, but considering you don't ever have to replace it. Just get a cheapo short ram from Ebay and put it in place of your stock arm.
1 Post
As far as the original question, I would say get a short ram, route it into the stock airbox, and stick a K&N in it.</TD></TR></TABLE>
i've got to disagree with you.my filter used to be directly behind the fan.when sitting in traffic or in the staging lanes,the filter is just sucking air right off the hot radiator...i moved it into the fenderwell and honestly noticed a difference.to say it doesn't matter doesn't make sense.you're talking about probably a 50 degree difference in air temp.that's like saying an I/C doesn't make a difference.having a measurable decrease in intake temp should equal lower temps after the I/C too.seems that would make a difference to me.
chris
chris
but i see you live in nd, a cai could be bad news as it can get wet in a puddle then freeze, which leaves you with a no air intake, and could kill your engine. id go with a ram air type, where the intake is under your hood, but not down underneath like a cai
Re: which filter/intake mod? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
You say that, but I would never run a turbo setup without an intercooler, and I have had my filter both in the fenderwell and under my hood, and noticed nothing. Pulling cool air and then heating it up in the turbo is going to end you up with hot air one way or the other.
EDIT: my original post was in response to another post..check that out..I don't think you saw it.
1 Post
the point i was trying to make was that the sole purpose of an i/c is to lower the intake temp as much as possible.assuming an i/c has the ability to lower the intake charge temp X degrees or X%(everything else being equal),it will always be lower by the time it reaches the engine if the air is cooler to begin with.people try to fit the biggest i/c they can on their car,which isn't always benificial,but never seem to worry about how they can effectively lower intake temps substantially just by changing the inlet placement.i've always wondered how much this affects actual power output,but i've never really seen anybody specifically researching it.hopefully in the next month i'll be on the dyno at P1,so maybe i can try to do some kind of comparison.
chris
chris
the point i was trying to make was that the sole purpose of an i/c is to lower the intake temp as much as possible.assuming an i/c has the ability to lower the intake charge temp X degrees or X%(everything else being equal),it will always be lower by the time it reaches the engine if the air is cooler to begin with.i've always wondered how much this affects actual power output,but i've never really seen anybody specifically researching it.hopefully in the next month i'll be on the dyno at P1,so maybe i can try to do some kind of comparison.
chris </TD></TR></TABLE>
Good stuff man!! My fenderwell got ripped up when I hit something in the road, so I relocated the filter back inside the engine bay. Did'nt notice any difference on the WB02 (and it gets leaner in the winter with the cooler air), so I doubt if it makes more than 5whp difference, or any difference at the track. Once you do find out, please let me know!! Now I'm interested!!
1 Post
Good stuff man!! My fenderwell got ripped up when I hit something in the road, so I relocated the filter back inside the engine bay. Did'nt notice any difference on the WB02 (and it gets leaner in the winter with the cooler air), so I doubt if it makes more than 5whp difference, or any difference at the track. Once you do find out, please let me know!! Now I'm interested!!</TD></TR></TABLE>
hmmm.if the maybe 50 degree cooler air in the winter makes a noticable difference on the O2,but the filter location didn't,it makes me wonder if the air in the area right behind the radiator really is signifigantly hotter....once you get moving and get outside airflow through the rad and into the engine bay to the filter,i'd think it wouldn't be much hotter than outside ambient temperature-at any reasonable speed the air moving through the rad couldn't be picking up enough heat to make for a very big increse in temp.....my main concern was sitting still with the filter a few inches from the rad,ingesting air that was basically just stagnant,soaking heat off the radiator.i always seemed to notice that the car felt very sluggish off the line,but seemed to pull like normal after a few seconds.i did try a very low-tech experiment by comparing how the car felt when i would sit for about a minute,then take off;and how it felt when i would quickly come to a stop,then take right back off.it always seemed to feel better when i would keep the air moving.once i relocated the filter,it seemed to perform the same either way.i know that's really no way to prove anything conclusive,but it did make me think it was at least worth leaving it in CAI style mount.
i would also like to get some kind of temperature probe and set it up where the filter used to be located behind the radiator,just to see how the temp changes,and how much it drops when moving.
chris
chris
I know on my mom's V6 Accord (I know, different car) the intake temps sit around 115 degrees when you sit still. In my car with the Type 24 fmic, my intake temps are always 80 degrees or lower. This is having the filter inside the engine bay behind the radiator. I wish I had bought the OBD software before, but you plug into your OBD2 port and you can see what all of your sensors see (and I was watching my IAT sensor).
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote"> In my car with the Type 24 fmic, my intake temps are always 80 degrees or lower. This is having the filter inside the engine bay behind the radiator. I wish I had bought the OBD software before, but you plug into your OBD2 port and you can see what all of your sensors see (and I was watching my IAT sensor).</TD></TR></TABLE>
is that when moving or sitting still?is that in boost or not?in what temperature weather is that reading?...
chris
chris
That's sitting still in like 70 degree weather. That was out of boost of course, as I was sitting still.
1 Post
That's sitting still in like 70 degree weather. That was out of boost of course, as I was sitting still.</TD></TR></TABLE>
did you ever get any readings of what kind of after i/c temps you have in boost?
chris
chris
I did, but I can't remember what they were. I'll go get some tomorrow and let you know.
EDIT: And on the last one I said about the temps, those conditions were for both the Accord and the Civic in the same night,
im sure this is a nub question but would adding a ram air (hoodscoop) over your intake filter improv
mattsnooz
03-11-2007 08:40 AM
1234567899876543211230
24
01-24-2007 07:22 PM
piggydog
10-13-2005 01:30 PM
