Overboost Stage 4 Gen III +200 HP Turbo Kit 1999-2000 Honda civic DOHC Si
Does anyone have this kit? Tell me how reliable if maintain properly with the correct equipment.
As the name implies, the Overboost 200+ Kit is intended for the serious racer - or those who simply want the best. Our 200+ kit includes all the electronic fuel, spark and MAP sensor controls as the other kits except uses four fuel injectors for top-notch atomization and mixture quality. We also provide two fuel pumps that can be run in tandem or used as auxiliary surge tank pumps for those of you running large fuel cells and expecting extreme-G launches. Expecting to run more than 20 pounds of boost? Be sure to let your Overboost Store representative know so we can provide you with the correct boost gauge.
Parts Include:
DRAG Gen III Turbo System
Two Airtex Fuel Pumps
GReddy Boost Gauge
GReddy Rebic IV Fuel Injector Controller
GReddy Turbo Timer
HKS 400 cc/min Injector x 4
HKS Fuel Cut Defenser
HKS Injector Connector
HKS Injector O-ring
HKS Steel Injector Cinch Fitting
HKS Variable Boost Controller
MSD 6A Boost Timing Master Ignition Control
Parts Include:
GReddy Boost Gauge
GReddy Turbo Timer
HKS Injector O-ring
Re: Overboost Stage 4 Gen III +200 HP Turbo Kit 1999-2000 Honda civic DOHC Si (mano77)
drag gen 3 = $2700
honda 4b = $1050
440cc inj = $300
apexi avcr = $400
walbro 255 intank fuel pump = $110
total $4560
That would be way better then the stage 4 kit.... i dont recommend boosting 20psi though on stock internals...
[Modified by GudeH23a, 10:27 AM 7/17/2002]
honda 4b = $1050
440cc inj = $300
apexi avcr = $400
total $4560
New User
Re: Overboost Stage 4 Gen III +200 HP Turbo Kit 1999-2000 Honda civic DOHC Si (GudeH23a)
damn, if you're boosting over 20psi wouldn't the revhard stage3 or custom turbo kit be the better choice?
Yeah, I was reconsidering that kit. A couple of guys in town are running them but they've had problems melting pistions. I guess not enough fuel or something. They didn't get into detail.
ki3t
05-13-2003 12:26 PM
