over boosting
Old May 18, 2011 | 06:57 AM
bigtom388's Avatar
Default over boosting
ok heres my problem guys, i got a boosted del sol with hondata boost control option, i keep over boosting and hitting boost cut even if its 80 degrees out ichecked the line goin to the bottom of my tial wastegate and cant find anything wrong with it also i checked the other line, i did jujst replace the pcv valve but im not sure if that would cause this problem.
Old May 18, 2011 | 07:26 AM
kyden's Avatar
Default Re: over boosting
do you hit spring pressure with the controller removed?
Old May 18, 2011 | 07:52 AM
darkvader0's Avatar
Did it just start doing this, or has it never worked for you?
Are you using just one line to the wastegate, or using the top port also?
Old May 18, 2011 | 07:13 PM
bigtom388's Avatar
it just started doing it outta no where, so i was looking at it today and pulled the 2 wastegate vac line off my vaccum block and checked them nothing was wrong so i put them back on and everything seems ok right now with the boosting i guess there might of been a kink but ill try it for a couple days and see how it goes, now the boost gauge aint working lol and i checked that everything is hooked up so if u have any insight on that be great and thanks for the response to the boosting problem guys
HondacivDX
Jan 1, 2011 10:36 PM
teamcalloway08
Jul 25, 2009 08:25 AM
tegedrex
Jun 10, 2004 11:22 AM
ATS*Mark
Mar 18, 2004 06:54 AM
Turbocivic94
Aug 7, 2003 05:39 AM
