Open Waste Gate
Old Mar 15, 2002 | 10:48 PM
ATurboCivic2NV's Avatar
Default Open Waste Gate
how many people in here are running open waste gates. does it make that big of a diffrence when it is open vs routed to exhaust.
i have not had the time to pipe it to the rest of my exhaust so i am not shure if i should do it.
Old Mar 15, 2002 | 11:51 PM
MiraiZ's Avatar
Default Re: Open Waste Gate (ATurboCivic2NV)
@you'll get about 10%-15% of your overall HP increased by going open wg....also a huge decible increase
[Modified by MiraiZ, 5:52 PM 3/16/2002]
Old Mar 16, 2002 | 01:22 AM
Dee's Avatar
Dee
Default Re: Open Waste Gate (MiraiZ)
I love the noise and exhaust smell created by my open wastegate...
Too bad I'm about to run it closed loop for stealth purposes.
Old Mar 16, 2002 | 05:43 AM
Default Re: Open Waste Gate (drealgsr)
thanks for the input
Old Mar 16, 2002 | 07:23 AM
Projekt20's Avatar
Any way something can be fabbed to run closed for the street and open for the track? Like a unboltable (if that's a word) tube you could bolt up to the DP and WG and then remove and bolt up another tube to route WG gases and have the DP hole pugged up with a metal plate that's bolted on to that. Lotta work....but somehow I think it's possible.
-Trung
Old Mar 16, 2002 | 11:06 AM
93LSivic's Avatar
Default Re: Open Waste Gate (Projekt20)
Sure, should be easy enough
-Trung
Just buy 4 w/g flanges and make a sort of test pipe, but just for the dump tube
Old Mar 16, 2002 | 12:07 PM
pkripper's Avatar
New User
Default Re: Open Waste Gate (93LSivic)
so thats what that nasty *** smell is i have a open wg, dhhhahahhah
i thought it was just cuse of the straght pipe.
to bad you lose so much hp.
has any one made a tube to make it vent to the out side of the car so you dont get the gases in your face.
Old Mar 16, 2002 | 12:17 PM
b18bvudoo's Avatar
New User
Default Re: Open Waste Gate (pkripper)
i have a tube that vents it to the bottom of my car. i dont think you should have that hot exhaust gas vented under yor hood.
Old Mar 16, 2002 | 01:28 PM
turbopanda's Avatar
Default Re: Open Waste Gate (vudoo666)
mine dumps to the floor, dont think having it leak out around the engine would be a good idea..
Old Mar 16, 2002 | 01:51 PM
Default Re: Open Waste Gate (nathan's boosted civic)
mine dumps right by the ac compressor and i have no problems with smell, i just have to clean the carbon off about every month.
Old Mar 16, 2002 | 04:54 PM
SIK IN DA HED's Avatar
New User
i got open WG and it sounds crazy! all you hear is vroooOOOOM BLLLLLLLATTTTT! people turn their heads so fast when they hear it. i scare the **** out of other racers. especially domestic owners!
Old Mar 16, 2002 | 05:05 PM
DragII's Avatar
25 Year Member
Default Re: Open Waste Gate (dlplayboy)
why is it that location of the closed loop makes such a differance?
Old Mar 16, 2002 | 05:35 PM
Flamenco-T's Avatar
Default Re: Open Waste Gate (SuperDragII)
http://turbomafia.com/Arturbo/direp9...0by%20DIRep.rm
it's loud.....chris still have nightmare of me flew by him on the tunnel...
stab
Old Mar 16, 2002 | 07:55 PM
MiraiZ's Avatar
-Trung
FMAX has a boltable dump tube....I personally like hearing my turbo and bov not the WG...it sounds like a huge exhaust leak!
Old Mar 16, 2002 | 08:51 PM
dustin's Avatar
Default Re: Open Waste Gate (94hondahybrid)
I dynoed today closed loop wg vs. open loop wg.
Closed loop lost no power whatsoever. I actually lost power open wg because it screwed up my AVC-R somehow and wouldn't boost at my selected boost...
Old Mar 16, 2002 | 09:56 PM
MiraiZ's Avatar
Default Re: Open Waste Gate (dustin)
I think it has something to do with where you route the exhaust too...if you route it after the cat, you lose less power, whereas if you loop it to the down pipe like most people do, you loose more power... of course...if you have no cat, I don't think they'll be much difference if any at all.
Old Mar 16, 2002 | 09:59 PM
dustin's Avatar
No cat, it loops back in about 2.5 feet after the turbo.
Old Mar 16, 2002 | 10:37 PM
Projekt20's Avatar
Got a pic?
-Trung
Old Mar 16, 2002 | 10:38 PM
dustin's Avatar
http://imglib.************/index.cgi?cmd=viewcat&id=154
gldndrgn14
Apr 19, 2008 09:23 PM
00BoostedGSR
Aug 15, 2006 02:46 PM
Diego Boost
Mar 22, 2003 08:20 PM
JMinSi2000
Apr 4, 2002 08:22 AM
