Ok to remove a/c bracket???)
Old Jun 9, 2005 | 06:43 PM
jagojon3's Avatar
Default Ok to remove a/c bracket???
I'm currently installing a .48/.60 T3 in my '92 civic DX (D15b7). I'm having some issues with clearance for the internal wastegate and was told to remove the a/c bracket. I figured it was weird that my car had an a/c bracket because it never had a/c. I removed the bracket, now people are telling me that it also acts as a motor mount, which it certainly looks like. How many of you have removed this bracket with no problems? Should I put it back on or will I be ok without it?
Old Jun 9, 2005 | 06:59 PM
Bailhatch's Avatar
Default Re: Ok to remove a/c bracket??? (jagojon3)
Dont run without it. You can cut it to make room for the WG actuator. I have done it several times with no trouble.
Old Jun 9, 2005 | 07:06 PM
jagojon3's Avatar
Default Re: Ok to remove a/c bracket??? (Bailhatch)
What did you cut yours with
Old Jun 9, 2005 | 07:53 PM
PrettyLude's Avatar
if you take it out, you will be putting more stress on the other mounts
Old Jun 9, 2005 | 07:55 PM
Bailhatch's Avatar
well on a couple cars I just had to grind down a the ridge by the upper left hand hole...used a 4.5" angle grinder on those. Some others I had to really take out some material so I used a sawzall.
Old Jun 9, 2005 | 07:58 PM
s2kdre's Avatar
if you have good motor mount inserts you can remove both lower mounts
Old Jun 9, 2005 | 08:30 PM
EnzoSpeed's Avatar
Default Re: Ok to remove a/c bracket??? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">if you have good motor mount inserts you can remove both lower mounts</TD></TR></TABLE>
Disregard that.
Old Jun 9, 2005 | 08:55 PM
jagojon3's Avatar
Default Re: Ok to remove a/c bracket??? (EnzoSpeed)
Damn I thought you guys were going to say that.
Old Jun 9, 2005 | 10:17 PM
EnzoSpeed's Avatar
Yeah, just cut the bracket. The bracket is huge - you can saw off the top 3/4 of it which will still leave the two bolts at the bottom for the trans mount.
Old Jun 10, 2005 | 05:41 AM
Bailhatch's Avatar
ehh think about how the force is applied to that bracket. I would not cut both of the top mounting holes off. More than likely if you just cut the upper left one off you will have room and still retain most of the strength. I wouldn't go further than that though.
Old Jun 10, 2005 | 05:47 AM
Chris F's Avatar
At least for Integras, there's a JDM (Type R?) aluminum piece that doesn't have the AC mount on it.
https://honda-tech.com/zerothread?id=1129216
-Chris
Old Jun 10, 2005 | 01:28 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">ehh think about how the force is applied to that bracket. I would not cut both of the top mounting holes off. More than likely if you just cut the upper left one off you will have room and still retain most of the strength. I wouldn't go further than that though.</TD></TR></TABLE>
Yeah, maybe you're right.
kid_02131
Feb 1, 2012 10:20 AM
jDmImagE
Oct 15, 2005 01:18 PM
KoRE
Dec 29, 2003 08:29 AM
ECKOTYPER
Dec 15, 2003 02:25 PM
