OK... now I'm almost done...
Old Aug 12, 2002 | 06:19 AM
M.A.R.C.'s Avatar
Default OK... now I'm almost done...
OK here's my setup so far:
>Garrett T-3 Turbocharger (.60A/R, 60-trim comp, .48A/R turbine)
>South Florida Performance Turbo Manifold
>South Florida Performance Downpipe
>Starion Intercooler
>Greddy Type-S Blow Off Valve
>Tial 35mm .45 Bar Wastegate
>Custom Charge Pipes (JC Whitney)
Fuel System:
>DSM 450cc Injectors
>88-91 Injector Resistor Box
>255lph Walbro High Pressure Intank Fuel Pump
>Calterm GM Injector harness clips
Electronics & Gauges:
>Apex'i V-AFC
>Greddy Turbo Timer
>Autometer Sport-Comp A/F Ratio Gauge
>Autometer Sport-Comp Boost Gauge
>NGK BCPR7ES-11 Spark Plugs
*Greddy 60mm Electrion EGT Gauge (Black Face)
Miscellaneous:
*Oil Feed Kit:
- 1ft of -4AN hose with straight steel hose ends
- (2) aluminum 1/8" NPT to 4AN fittings
- Brass T Fitting
- 4ft of -4AN hose with steel hose ends (90º and one straight)
- Steel 1/8" NPT to 4AN fitting
- Steel 1/8" BSPT to 1/8" NPT Adapter
*Vacuum hoses
*Silicone couplers/2.0" & 2.5" radiator hose
*1/2" NPT T3 Oil Drain Flange
*Greddy Type-S Blow Off Valve Flange
* -10AN Oil Return Line Kit
just waiting on the stuff with the * next to it to be delivered. Should be done and installed either this weekend or like mid week next week.
Old Aug 12, 2002 | 11:41 AM
Midwestrider's Avatar
Default Re: OK... now I'm almost done... (CivicRyda2k)
Congrats man on the custom setup...
Old Aug 23, 2002 | 07:10 PM
M.A.R.C.'s Avatar
UPDATE:
>Starion Intercooler
Fuel System:
>DSM 450cc Injectors
>Apex'i V-AFC
>Greddy Turbo Timer
Miscellaneous:
>Oil Feed Kit
all i need now is for someone to make the adapters for the compressor housing inlet/outlet, get the brass Tee, and some vacuum hoses and clamps.
Old Aug 24, 2002 | 11:01 PM
dvp95's Avatar
UPDATE:
>Starion Intercooler
Fuel System:
>DSM 450cc Injectors
>Apex'i V-AFC
>Greddy Turbo Timer
Miscellaneous:
>Oil Feed Kit
Just out of curiosity, how much has this cuztom setup costed you? Im debating whether to go custom or buy a kit. Im leaning towards a custom kit since ill get the best parts (well what I think is best). However, I just dont know what all to get. How long has it taken you to piece everything together? Thanks
Old Aug 26, 2002 | 12:33 PM
M.A.R.C.'s Avatar
Default Re: OK... now I'm almost done... (dvp95)
the setup has cost me about $2600ish including everything needed to do the install. It took me about 3 months to put it all together but that's really because of my budget (19yr old college student) and that was kidna the reason i went custom... so i could do it piece by piece without a large one time investment. I did a lot of research here on h-t and from turbo friends to know what all to get for the kit. Deciding whether to piece together or buy a kit all depends on ur circumstances. I say if you just want something for the street that will work at lower boost levels (6-8psi), buying a kit should be fine. If you want something that will be able to make power and safely, etc and u know what ur doing, i'd go with piecing together a kit so u can pick the components u know will support ur goals. OR if ur like me and work on a budget u can also piece it together (for even less than i did) and have more flexibility. Also if ur pieceing together and u don't know much u end up learning alot about the components. Hope that helps. dunno if u were a newbie or just wondering whether to go custom or kit . good luck
b18sihatch
Jul 11, 2006 07:06 AM
Pythagoras
Dec 25, 2005 07:38 PM
M.A.R.C.
Jul 7, 2002 10:09 AM
M.A.R.C.
Jun 25, 2002 07:31 PM
M.A.R.C.
Jun 18, 2002 01:17 PM
