need help with gt35r
Old Aug 22, 2006 | 08:07 PM
high boosted rex's Avatar
Default need help with gt35r
i was wondering if someone can help, with my coolant lines for the turbo, its on a gsr engine, where do i hook them up to, and what fittings do i use? if someone can help me, or show pics that would be awesome thanx.
Old Aug 23, 2006 | 06:43 AM
no one can help me
Old Aug 23, 2006 | 08:17 AM
93supercoupe's Avatar
Default Re: (high boosted rex)
tap them off ur heater core lines, remember flow direction though
Old Aug 23, 2006 | 09:04 AM
rip94delsol's Avatar
one off the water pipe in the back and the other one off the water neck off the head thats how my setup is!
Old Aug 23, 2006 | 01:47 PM
BB6-213's Avatar
I just ran mine inline with the IACV coolant lines.
Old Aug 23, 2006 | 07:35 PM
but how would i do them braided? anyone know what fitting i need, and anyone have pics, thanx for the info so far
Old Aug 24, 2006 | 02:33 AM
BB6-213's Avatar
I just did an-6 hose with fittings on one end and I just used 2 brass hose barbas on the other with a hose clamp, It's deffinatley not ideal, but it isn't a high pressure system and looks fine, you cant even tell.
Old Aug 24, 2006 | 07:03 AM
spoolingb20's Avatar
Default Re: need help with gt35r (high boosted rex)
I know right up front on your block there is a plug you can take out for the coolant supply line and that is only inchs from your turbo.
I ran mine with the supply and return off the heater core. I just got two brass T's and from there ran the line to the turbo. There are kits available for the banjo fittings that feed off the front and rear of the turbo that will run hard lines like 6 inchs away from the turbo. Ben from Importparts.com could set you up with a kit like this.
It also doesnt matter which line is the supply and return coming into and out of the turbo either or will work...
91rexhf
Dec 25, 2008 10:02 AM
XSIintegra
Aug 27, 2008 06:03 PM
JDM00SI
Jan 8, 2007 09:06 AM
Mr HYDE
Oct 2, 2006 06:07 AM
airwalk07143
Jan 1, 2004 08:36 AM
