Ok Big Problem - Overflow EXPLODING When I Boost Hard. Solution?
Old Sep 9, 2006 | 04:19 PM
  #101
Flashmn's Avatar
Default Re: (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">maybe you dont understand the situation, I live in a butfuck town, no real stores. I have to work monday morning 35miles from home with no parents to drive me</TD></TR></TABLE>
I live 7km from a town with less than 20,000 people, and I can get a head gasket on the next day when I order one. So that is just a bad excuse.
Take the bus to work, heck might be more reliable than driving in a car which is about to explode in the first place.
Old Sep 9, 2006 | 04:31 PM
  #102
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: (Flashmn)
My village has 1800, thanks for trying
Old Sep 9, 2006 | 05:26 PM
  #103
SOHC_MShue's Avatar
Default Re: (PINKS)
Do you have a wideband to check afr's? If you do and your afr's are in the 11.0-12.0 range then you NEED to pull timing. Get it on a dyno.
Old Sep 9, 2006 | 05:35 PM
  #104
alpha's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">I do however have another problem, Ive snapped a second arp stud
I dont know whats going on with these studs, they are absolutely bottomed out, I torqued in the correct pattern to 25 ft/lbs, then 55 ft/lbs and everything was fine. When I stepped up to 80 ft/lbs the middle lower stud snapped. Just like the last one, flush with the bottom of the nut
I dont get why they break, the nut after the 55ft/lbs torque didnt feel to get any tighter through the 1/4 turn I slowly brought it through and then it snapped.</TD></TR></TABLE>
I have never had this happen. I would say your torque wrench is out of calibration
Old Sep 9, 2006 | 05:45 PM
  #105
nsxmatt's Avatar
Default Re: (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">I have never had this happen. I would say your torque wrench is out of calibration</TD></TR></TABLE>
Is he using one or is he actually pounding it 55 times with his foot?
Old Sep 9, 2006 | 05:47 PM
  #106
Archidictus's Avatar
Unceasing Measure
LOL!
Old Sep 9, 2006 | 05:49 PM
  #107
Whiteintegra's Avatar
common guy, take the advice of others. knowledge is power
Old Sep 9, 2006 | 06:07 PM
  #108
PINKS's Avatar
Default Re: (Whiteintegra)
Yeah ive got a wideband and the car actually runs rich in boost, about 10.9 til about 10psi then it holds 11.3-11.5 to 15
My torque wrench is new but maybe its just to big, I dont think that would matter, but its 30inches long
Old Sep 9, 2006 | 07:16 PM
  #109
SOHC_MShue's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Yeah ive got a wideband and the car actually runs rich in boost, about 10.9 til about 10psi then it holds 11.3-11.5 to 15
My torque wrench is new but maybe its just to big, I dont think that would matter, but its 30inches long</TD></TR></TABLE>
if its running those afr's then like i said pull out timing.
Old Sep 10, 2006 | 05:09 AM
  #110
PINKS's Avatar
Default Re: (Mr Wonderfull)
You honestly believe I am running to much timing with it though? Seems fairly conservative compared to other maps Ive looked at
Old Sep 10, 2006 | 05:46 AM
  #111
sc4dr's Avatar
Default Re: (PINKS)
I just read how you checked your head with a straight edge. You got that part right, but you forgot to mention the part where you slid your feeler gauge underneath of your straight edge all the way across. You did check it with a feeler gauge?
Old Sep 10, 2006 | 07:03 AM
  #112
SOHC_MShue's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">You honestly believe I am running to much timing with it though? Seems fairly conservative compared to other maps Ive looked at</TD></TR></TABLE>
other people have different setups. Dont risk another headgasket. Take it to the dyno and find out where the timing needs to be set. I'm running about the same timing on 10psi as you are running on 15psi with my z6head/y8block setup. Anymore timing and i can hear knock through my det cans i made. Sohc's just cant take much timing.
Old Sep 10, 2006 | 07:07 AM
  #113
Boostfed's Avatar
New User
Default Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">i had same issues long time ago. i switched to a koyo racing radiator and it solved the issue. I wnt with koyo because it's bigger than the others, the end tanks are larger and flow more, and it's lifetime warranty. i got mine from http://www.radiator.com</TD></TR></TABLE>
BS! I made 616whp on a stock radiator pushing 28psi on a T4/T67. Get otu of here with that ****!
Old Sep 10, 2006 | 07:11 AM
  #114
PINKS's Avatar
Default Re: (sc4dr)
Yes I checked with a feeler gauge and I couldnt fit anything other than a .003" piece through, well within spec
You guys will have to enlighten me on the timing though, no I dont have access to a dyno within 800miles
Old Sep 10, 2006 | 07:35 AM
  #115
swappedcx's Avatar
Default Re: (PINKS)
800 miles...where the hell do you live?
Old Sep 10, 2006 | 08:00 AM
  #116
SOHC_MShue's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Yes I checked with a feeler gauge and I couldnt fit anything other than a .003" piece through, well within spec
You guys will have to enlighten me on the timing though, no I dont have access to a dyno within 800miles</TD></TR></TABLE>
then you should make this https://honda-tech.com/zerothread?id=1555006
Old Sep 10, 2006 | 08:08 AM
  #117
nsxmatt's Avatar
Default Re: (swappedcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcx &raquo;</TD></TR><TR><TD CLASS="quote">800 miles...where the hell do you live? </TD></TR></TABLE>
******* Gtown
Old Sep 10, 2006 | 09:12 AM
  #118
Blaze45's Avatar
Brrraaaap!
Default Re: (nsxmatt)
What kills me is there are tons of other posts here on HT that people desperately need help with car problems and nobody posts in their threads (including myself Im lazy haha) but this guy has had his problem with his car diagnosed over the internet like 50 times and in multilple threads multipule times and on different forums as well. I dont understand how his threads get past the first page let alone 6??? I was gonna tell him once again what he needed to do, but realized that its already been beat to death. I think this guy just likes to see his owns posts.
Old Sep 10, 2006 | 09:25 AM
  #119
PINKS's Avatar
Default Re: (Blaze45)
You do know that I swapped headgaskets, flushed my cooling system, retuned my car, made a new manifold and downpipe all within this thread though right man
Alot of peoples questions dont get answerred because they are asking **** about wings and differetn sized turbos, this is a problem that people run into aprently and I was WRONG trying to fix everything else and appreciate the help I got steering me in the right direction
Thank you
Old Oct 21, 2006 | 02:26 PM
  #120
clayne's Avatar
Default Re: (PINKS)
https://honda-tech.com/zerothread?id=1599953
Old Oct 21, 2006 | 05:56 PM
  #121
THEDirtyDseriesWOOT's Avatar
blown gasket .. change it.. then retq the arps with the MOLY LUBE! 10w30 u have to tq to 85 ft lbs... i did it once and my arps were all fubar the next time i had to change it they were all stripped.. just get the moly u will save urself the trouble and get the head milled the heat has most likly warped it thats why u need a new gasket in the first place .... im spent
Old Oct 24, 2006 | 05:27 PM
  #122
MrPotatoeHead's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Alot of peoples questions dont get answerred because they are asking **** about wings and differetn sized turbos, this is a problem that people run into aprently and I was WRONG trying to fix everything else and appreciate the help I got steering me in the right direction
Thank you</TD></TR></TABLE>
WOW HOLY expletive.....He finally relized that if he listened to all the SAME answers it would fix his problem. AND I HIGHLY doubt that you "BUILT" other motors let alone the one in your car. If you had the experiance to build motors you would have known to use lube on the arp's, and most of all, not to re-use a headgasket. Oh and if you had any common sense you'd know not to go and take your car out for drives with it fucked up like it is. Do the world a favor and get your self a stock car and drive it, dont modify it AT ALL. AND MOVE THE expletive OUT OF THE IMBREED CAPITOL OF THE WORLD.... expletive YOU ARE STUPID
Caps mean im yelling.
Old Oct 24, 2006 | 06:36 PM
  #123
error's Avatar
Default Re: (MrPotatoeHead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrPotatoeHead &raquo;</TD></TR><TR><TD CLASS="quote">WOW HOLY expletive.....He finally relized that if he listened to all the SAME answers it would fix his problem. AND I HIGHLY doubt that you "BUILT" other motors let alone the one in your car. If you had the experiance to build motors you would have known to use lube on the arp's, and most of all, not to re-use a headgasket. Oh and if you had any common sense you'd know not to go and take your car out for drives with it fucked up like it is. Do the world a favor and get your self a stock car and drive it, dont modify it AT ALL. AND MOVE THE expletive OUT OF THE IMBREED CAPITOL OF THE WORLD.... expletive YOU ARE STUPID
Caps mean im yelling.</TD></TR></TABLE>
and ur a dick
Old Oct 24, 2006 | 06:50 PM
  #124
shortyz21's Avatar
Default Re: (error)
i didnt read this topic, but did u resurface the head when u replaced the headgasket? did u have it pressure tested also?
warped head, cracked head.
i just went through the exact same ****..
Old Oct 24, 2006 | 08:20 PM
  #125
Default Re: (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">
and ur a dick </TD></TR></TABLE>
WOW you must be friends with this guy or live the same life.
