Oil vapor from catch can????
it seems at idle i have alot of vapor that comes out of my catch can. im using the endyn setup. have one line on the back of the block going to a top port.the drain on the bottom back to the other port on the back of the block. i also hooked up the valve cover stock port ran to the other top port of the catch can
has anyone had this issue??
Re: Oil vapor from catch can???? (AK94GSR)
i have some smoke/vapor that comes out at idle too, especially when the motor is cold. im using the z10 setup. i think its relatively normal. i wouldnt worry unless u have bad compression or high leakdown
petwhookie
69
03-12-2010 03:50 PM
accord99power
03-05-2010 05:43 AM
