Turbo car With Cat
Old Jun 1, 2008 | 09:18 AM
crazy_ls_90's Avatar
Default Turbo car With Cat
i have a 93 civic with a GSR turbo swap, and it still has the cat on it, if i cut it off will it boost more?? and if so how much more?? I know it should spool quicker.
any help is appreciated... thanks
Old Jun 1, 2008 | 09:24 AM
champLSinteg's Avatar
Default Re: Turbo car With Cat (crazy_ls_90)
It should not boost more. I was boosting 10psi on my stock 2.25in exhaust then I went with a full 3in exhaust and it boosted the same but spooled faster. I did not have it retuned after I did this and the ringlands went out on all of the pistons. I was making 280 at 10psi with a 60trim. With the 3in and new motor it was making 320 at 10psi so you can see how much a restriction it was and why I needed to retune.
If you tuned the car with the cat on make at least make sure the air/fuel is fine after you take it off.
Old Jun 1, 2008 | 09:27 AM
Default Re: Turbo car With Cat (champLSinteg)
ok thanks..
the car was tuned with the cat on it. its tuned at 9psi with a T3/T4 on crome.
What do you think the HP is??
Old Jun 1, 2008 | 10:24 AM
grndcont's Avatar
it wasnt tuned on a dyno?
Old Jun 1, 2008 | 10:31 AM
Default Re: (grndcont)
If it was street tuned then make sure you have your tuner check things over again.
Old Jun 1, 2008 | 10:40 AM
Default Re: (champLSinteg)
No it was Street tuned.
He did a Good Job
jasonjai
Mar 1, 2012 05:28 PM
w0ng_sta
Sep 17, 2006 08:20 AM
datspeed77
Aug 14, 2002 07:55 AM
HENRY
Oct 9, 2001 07:34 AM
