Oil on tailpipe. Seals?
So as I was getting something outta my trunk today I noticed that there was oil on my tailpipe!
No blue smoke just black oil.
On my lunch break I drove home and did a compression test... 210 across the boards and plugs looked clean.
Sounds like the turbo seals to me... what about you?
I also quickly popped off the IC piping and it was clean so is that common that the exhaust seal bust before the compressor seal? I thought it was the other way around. Well I gotta pull off the DP and Turbo when I got time
No blue smoke just black oil.On my lunch break I drove home and did a compression test... 210 across the boards and plugs looked clean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">Ive seen blown seals spit oil into the downpipe, but it also blows a huge cloud of blue smoke. </TD></TR></TABLE>
How would that happen? I can't think of anything causing the oil to combust.
I had a similar problem. https://honda-tech.com/zerothread?id=1544369
