Oil shooting from BOV.....HELP
I purchase RH Stage II turbokit for RH 2 months ago...i got a GT30R BB turbo....i noticed oil all over the top of the hood from the wind..i open the hood and there was oil all over underneath my hood...i is coming out of my BOV... my compression is bad too...i think i may have tap the oil pan a little to low too...i need help and suggestions....
If you tapped the oil pan too low than that is your problem. The drain line has too much restriction so oil is blowing by your seals into your intake. I'd be more worried about the gobs of oil that may getting into your intake manifold than the oil coming out of the BOV.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">If you tapped the oil pan too low than that is your problem. The drain line has too much restriction so oil is blowing by your seals into your intake. I'd be more worried about the gobs of oil that may getting into your intake manifold than the oil coming out of the BOV.</TD></TR></TABLE>
yeah there was oil puddle in my throttle body...could my oil seal be shot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endoe »</TD></TR><TR><TD CLASS="quote">
yeah there was oil puddle in my throttle body...could my oil seal be shot?</TD></TR></TABLE>
So oil IS coming out of your BOV for sure? Take off the piping and check it out.
If there is oil all over inside the compressor housing than you have a blown seal.
Post ups pics of your feed and drain lines for us too check out.
I took off my turbo setup already...and there is oil in my piping...is it possible to have oil in my piping because of the oil return is too low instead of a broken oil seal?
It is possible. Pressurizing the cartridge will make the seals fail, but not immediately. Oil will leak before the seals actually give out, so if you correct the problem quickly you may luck out and not have to rebuild the turbo.
that day i came home and sat my car until i took off the turbo... the car drives fine but not as strong because of my blown piston rings..i'm planning to throw a new motor in there but im not sure because of my turbo situation?
97grnrs
Nov 21, 2006 10:35 AM
D16y8_619
Sep 8, 2006 09:05 PM
riceball777
Jul 27, 2006 11:33 AM
