oil returns
Old Feb 14, 2004 | 09:49 AM
808b18c1boosted's Avatar
Default oil returns
I hate the drag oil return set up. It leaves my **** all oily does any one have alternatives to this setup like Russell's fittings. anyone got the an sizes they use and oil the adapters i need. thanks
Old Feb 14, 2004 | 11:14 AM
T-RO's Avatar
the kits put out by Flamenco-T are very popular on this board.
do a search...
Old Feb 14, 2004 | 11:17 AM
r1lorenzini's Avatar
Default Re: (T-RO)
i used dash-10 an lines with a bulkhead fitting in the oilpan... i can cee the nylon washers being saturated but not leaking (yuet)) that is the only part of my kit not leaking...damnn itttttttttttt
Old Feb 14, 2004 | 11:18 AM
Flamenco-T's Avatar
Default Re: oil returns (808b18c1boosted)
The oil return line kit,
You do need to have a threaded oil drain flange for the oil return kit, most turbos comes with it, if not, I can supply you with an aluminum billet flange and gasket.
stan
Old Feb 14, 2004 | 11:19 AM
Flamenco-T's Avatar
Default Re: (r1lorenzini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1lorenzini &raquo;</TD></TR><TR><TD CLASS="quote">i used dash-10 an lines with a bulkhead fitting in the oilpan... i can cee the nylon washers being saturated but not leaking (yuet)) that is the only part of my kit not leaking...damnn itttttttttttt</TD></TR></TABLE>
why don't just weld it, no more worry about the washer seeping oil through it..
I sell it both with weld and non weld, but I always recommend a weld version, unles you really have no access to a welder.
stan
Old Feb 15, 2004 | 09:38 AM
Default Re: (Flamenco-T)
do you guys think 10 an is to big.
Old Feb 15, 2004 | 09:46 AM
99blackcivicSi's Avatar
Default Re: (808b18c1boosted)
no
Old Feb 15, 2004 | 09:56 AM
ebp 99 si's Avatar
Default Re: (99blackcivicSi)
order the kit from flamenco-t
i did and it looks great
can't wait to get it on the car along with the rest of my setup
Old Feb 15, 2004 | 10:28 AM
RedStarGsr's Avatar
flamenco has the best kit around, everyone runs it, and everyone loves it.
Old Feb 15, 2004 | 10:33 AM
ghettocrxsi's Avatar
Default Re: (RedStarGsr)
I have his feed and return line kit.
Old Feb 15, 2004 | 12:00 PM
Default Re: (ebp 99 si)
does he also have the barbed fittings.
hondaeg8
May 22, 2006 03:12 PM
Bimmerman
May 5, 2005 05:46 PM
AzntaggeR
Oct 5, 2004 11:08 AM
UsaTLinh
Jun 2, 2004 10:58 PM
SuperDonkey
Dec 10, 2002 06:16 PM
